Hooking up wideband 02 to profec
Started by markiii, November 26, 2005, 23:20
OK guys it's about time I did this and I have teh profrec ionstalled and Innovat LM1 Wideband in a box, and the external signal harness for teh profec.
And no clue which input to use or how to calibrate it.
any ideas?
Yes,
Select which channel you want to use, in the first column from left to right put
volt 0.12 - conversion 10
then 2nd column put volt 4.62 - conversion 19
thanks for that, can you explain what it means though?
and daft question but I assume you mean pick which analog input? I'm assuming that it won't be one of teh pulsed inputs
Quote from: "markiii"thanks for that, can you explain what it means though?
and daft question but I assume you mean pick which analog input? I'm assuming that it won't be one of the pulsed inputs
No not 1of the pulsed inputs, it's 1 of the 2 analog inputs, see pg 24 of the e-01 useless instruction manual   s:? :? s:?   You can use either i used channel 1.
Does the LM1 wideband output 1-5v or 1-2v ?
