Disabling reverse gear bleeps...
Started by Anonymous, February 14, 2008, 21:29
As above really. I find it incredibly annoying because I know I'm in reverse! Is there a fuse i can pull or another method somebody has used? If it's a fuse can anyone tell me where to find it?
Likewise the seatbelt bleeps...
Thx all.
Miche.
enid_b
cant help with the reversing, but if you reach under the passenger seat, there is a wire which connects to the seat. simply unplug that wire, and hey presto, the light stops flashing and the beeps also stop.  similar for the drivers seat, but i would not recommend removing that one.
E
There is a wire above the instrument cluster that needs to be cut, 2 minute job, i wired in a switch so that i can turn off the bleeper when reversing, and back on afterwards.
I believe there is a how to on spyderchat.
Or here.
Search is really the best way, most things have been talked about before - so I will lock this and any more comments can be added to the earlier thread to keep them in one place
MOD: Thread locked to avoid duplication
