What type of weld is normally used for these manifold joints? I have a MIG welder. I'm not sure this is sufficient, joking aside I'll giving it a bash. Who'd the guinea pig... I mean first victi... trial... erm... who's first? s:P :P s:P
I can weld and have my own welder, but i'm not much use as i'm miles away from most of you. s:x :x s:x
Lee you'll need some stainless steel mig wire and argon gas.
Quote from: "mr-s_turbo"Lee you'll need some stainless steel mig wire and argon gas.
I have that, is this sufficient for welding a turbo manifold though? If so we're set.
Yeh that's all you need. The welder needs to be a good amp rate really but 100amp+ will do.
hmmmmm
How about a adult education course, in say, welding and fabrication s:D :D s:D
Funnily enough I was looking at (trying to find) evening courses the other weekend (Mechanics qualifications ones, actually, but that'd be good too).
Anyway.. we should get back on topic, really - we're dragging Mark's 'updates' thread about a little too much s:oops: :oops: s:oops:
Quote from: "philster_d"hmmmmm
not such a silly idea with the amount we could use of a descent welder.
p.s. your brackets are done Phil s:wink: :wink: s:wink:
Thanks alot, potential future welding star s:wink: :wink: s:wink:
/Philster.
I know a bloke who does MIG/TIG welding.. if that at all helps! s8) 8) s8)
So whats teh difference between MIG and TIG?
MIG welding is cheaper, requires less skill and doesn't need a lot of cleaning afterwards. TIG welding is more precise, doesn't need a filler metal, free of spatter and has low distortion.
Also, with MIG welding the wire is fed continously from a spool, whereas TIG (if used with a filler metal) is done from a single rod.
All info from here (http://www.weldingengineer.com/), so I'm no expert suddenly. s:wink: :wink: s:wink:
When the BMW guys welded my manifold they used a high melting stainless steel rod, they said the lower melting rods wont hold the extream temperatures of the manifold, does this make any sence?..
Quote from: "dimwit"When the BMW guys welded my manifold they used a high melting stainless steel rod, they said the lower melting rods wont hold the extream temperatures of the manifold, does this make any sence?..
Did you get yours done locally Graham?
[/quote]
Did you get yours done locally Graham?[/quote]
They done it at work for me, well at Oxford, and brought it back to work for me welded up the following day..
Quote from: "markiii"So whats the difference between MIG and TIG?
MIG...Metalic Inert Gas
TIG...Tungsten Inert Gas
Can do all four
MIG, TIG, Manual and gas
I'm best at oxyacetalyne (can't spell it) this is probably overkill, looks damn good though!
