Just s:shock: :shock: s:shock:
In 2006 my emissions figures were:
Fast idle:
CO: < 0.20%vol
0.00%vol PASS
HC: < 200ppm vol
1ppm vol PASS
λ : 0.970-1.030
1.003 PASS
Natural idle:
CO: < 0.30%vol
0.00%vol PASS
And this year:
Fast idle:
CO: < 0.20%vol
0.04%vol PASS
HC: < 200ppm vol
21ppm vol PASS
λ : 0.970-1.030
1.030 PASS
Natural idle:
CO: < 0.30%vol
0.00%vol PASS
So I'm a little up on CO & HC, and the lambda value is right on the upper limit (lean)..
Given the calculation from Lambda to AFR, last year I had an AFR of 14.74, and this year it's up to 15.14:1..
Still - that could be anything, from the fact that I reset the ECU yesterday to a sensor going slightly out of spec..
Still, it passed, and the only advisory was handbrake travel - home free for another year s;) ;) s;)
</pointless post>
I worry about the calibration on some of these MOT probes ... and we've seen before how easy it is to get a lean reading because of the tailpipe bends - its tripped up a few people before now. s:? :? s:? s:wink: :wink: s:wink:
Still, you're cool for another year Aaron. Nice one s8) 8) s8) .
</pointless retort>
Aye you're right - just found my original MOT (2005) which had higher CO still (0.1%) and a lambda of 1.017 - so it's been there or thereabouts for three years now..
Nothing to worry about, I'm sure s:) :) s:)
Now I just need to get around to buying some new brake discs and resetting the handbrake travel s;) ;) s;)
now thats what you call skin of your teeth s:shock: :shock: s:shock:
Yep - I believe his comment was "Had a little trouble with the emissions.. it took a few goes.." s;) ;) s;) Good bloke though - most would fail it on the first attempt..
Just for the record, I was a bit worried about the Che manifold without pre-cats, but:
Fast Idle Test
CO 0.032 pass
HC 0 pass
Lambda 1.002 pass
Natural Idle Test
CO 0.054 pass
Got stung for front discs and pads though - should have checked
Anyone had an MOT with the SP downpipe yet?
I think Muffdan did with no probs - got mine due soon, going to get mine so hot before it gets there it will be smoking!
Hi Aaron .. Ive looked at those results ... theres nothing to worry about with the co's ... this is just how hot your cat is .. if you took it for a quick blat it would go down to 0.00 or 0.01 ,, but looking at the lambda result it maybe that you have a small hole in your exhaust .... failing this he maybe hasnt had the probe stuck right up its arse..
And SPIT .... calibrations are done every 6 months. There are strict mot laws and most machines wont even let you carry out the test if not calibrated (by an independant co.) And you do a leak test and a HC zero etc everday , so they are pretty accurate ... cheers hope this helps s:lol: :lol: s:lol:
