well, finally got bored of that crappy looking standard exhaust poking out the bottom of my car like a bet straw and decided to turn to ebay!
2 days later and I have a box in the porch with shiny things in it!
(http://i180.photobucket.com/albums/x271/markmrx/mr2%20exhaust/IMAG0684.jpg)
(http://i180.photobucket.com/albums/x271/markmrx/mr2%20exhaust/IMAG0686.jpg)
In all its uglyness:
(http://i180.photobucket.com/albums/x271/markmrx/mr2%20exhaust/IMAG0694.jpg)
ended up having to cut the rubbers to get the dam thing off :/
anywho, A tip to the welding shop for some tig wire and a bottle of gas and its time to get to work.
I knew this would be the hardest bend to get right so I set it all up and locked it in place...
(http://i180.photobucket.com/albums/x271/markmrx/mr2%20exhaust/IMAG0698.jpg)
(http://i180.photobucket.com/albums/x271/markmrx/mr2%20exhaust/IMAG0700.jpg)
next up was a mini cut and shut to make room for the exit pipe i just welded:
(http://i180.photobucket.com/albums/x271/markmrx/mr2%20exhaust/IMAG0696.jpg)
(http://i180.photobucket.com/albums/x271/markmrx/mr2%20exhaust/IMAG0697.jpg)
now for a rest fit:
(http://i180.photobucket.com/albums/x271/markmrx/mr2%20exhaust/IMAG0703.jpg)
tack it all up:
(http://i180.photobucket.com/albums/x271/markmrx/mr2%20exhaust/IMAG0704.jpg)
remove and weld:
(http://i180.photobucket.com/albums/x271/markmrx/mr2%20exhaust/IMAG0706.jpg)
I also thought it would be a good time to sand some rust off and paint it all up quick!
Job done:
(http://i180.photobucket.com/albums/x271/markmrx/mr2%20exhaust/IMAG0713.jpg)
I was planning to weld on the end of the new astra vxr exhaust onto the end but I ran out of gas ring on the last exhaust hanger. Managed to use up a 5l bottle! In honesty tho, i think it's better left as it is. I do need to paint the number plate surround and finish off the trim round the exhaust. Job for another weekend.
s8) 8) s8)
Video from inside:
http://s180.photobucket.com/albums/x271/markmrx/mr2%20exhaust/?action=view¤t=VIDEO0100.mp4
Couldn't you just have polished the bit that people can see ? They do come up really shiny chrome with a bit of elbow grease.... s:wink: :wink: s:wink:
where is the fun in that? s:) :) s:)
Mmm, lots of work, little gain.
Quote from: "M R 2"Mmm, lots of work, little gain.
If for the fun of it and to be different isn't enough, I have this waiting for new crank bearings in the shed:
(http://i180.photobucket.com/albums/x271/markmrx/roadster/DSCF0628.jpg)
and a turbo in the loft s;) ;) s;)
You not too bothered about it melting the plastic?
Looks good dude! s:) :) s:)
Hats off to you for trying something different! Excuse my ignorance but whats the engine out of?
Quote from: "JiMR2"Looks good dude! s:) :) s:)
Engine is a Yamaha so my guess is 2ZZ
Does cutting the rear crash bar make it less efficient as a crash bar?
Quote from: "Les"You not too bothered about it melting the plastic?
naaaa, been driving it about all day and doesn't seem to hurt it as long as it doesn't touch it. I plan on cutting it back a bit and putting a metal surround in just in case s:) :) s:)
The engine I got off ebay. It was out of a corolla t sport. Ripped it up and had 2 big ends gone. I got new rods, rings and checked everything. It's all good bar waiting on the dam crank bearings for months now :/
as for the bar, I welded in new sections in the U shape I cut out (have to look close to spot it), shouldn't be a problem! s:) :) s:) Tho how flimsy it is, I doubt it would stop much anyway!
