I replaced the lower steering U/J today and had a little inspection around under the frank. I noticed that the radiator will need replacing soon. I also noticed that it only had one fan on the back of the radiator. Is this right? There is space for two.
I don't have any overheating issues the needle sits bang on half way when it is warm. Should i fit another fan?
You only get a second fan if you have aircon.
mystery solved...thanks
I'm reading that it's beneficial to fit the second fan, if you don't have A/C and are planning to track your MR2? I've also read of people taking the fans off and installing a better flowing radiator?!
I'm about to replace my radiator and wondering whether to invest in a trick radiator or fit a second fan..??
