hallo all
I started to prepare my zz2 motor swap in my spyder 2000 and have some questions. s:D :D s:D
what's my stock gearbox name, what does it take to use it.
would it be an benafical with an ultra-light flywheel and clutch?
is there other than MWR has plug n play wire set to ECU.
greeting jørgen
Have a look in the Engine Swaps section. There's a fair bit of info in there about these questions.
The flywheel is definitely something I'd do. Especially with that engine.
Thanks i reading alot about the swap
