Hello
I want to show car i bought over 1 year ago and whole way to present form.
It`s w30 facelift 2005.
Hardtop, air conditioner, lsd. Rest stock.
(http://s4.postimg.org/4jc6hefxp/MG_9694.jpg)
And i started to learn that car on tracks.
(http://s13.postimg.org/3zsha6dtj/DSC01679.jpg)
I started to change:
Tyres yokohama ad08r
Lower springs
Motul rbf660
Brake pads (front ferrodo 2500) (rear EBC yellow pad)
Steel brake hoses
Whiteline sway bars
Whiteline camber bolts
And i was driving almost whole year that setup
(http://s32.postimg.org/tnee43h79/13147748_1007530329337709_4386919096811863969_o.jpg)
Then i changed seats.
Seats from Toyota gt 86 are about 8kg heavier but more comfortable with better holding.
(http://s33.postimg.org/73oxdigbz/DSC_0174.jpg)
(http://s33.postimg.org/kyvw9b1nj/DSC_0177.jpg)
(http://s33.postimg.org/bsvz4zpy7/DSC_0178.jpg)
We cut orginal mounts and weld to gt86 rails.
(http://s33.postimg.org/gg9uc4d9b/DSC_0173.jpg)
(http://s33.postimg.org/9vbd0yihr/DSC_0175.jpg)
cons:
-2cm higher seat
And oil cooler
(http://s33.postimg.org/k0xm4v2nz/DSC_0175.jpg)
Now i know that it was not enough for motul v300 5w30.
After 1 year we decided to go futher.
I bought corolla ts with bemani supercharger.
(https://s32.postimg.org/y18etjh5x/abc.jpg)
(https://s32.postimg.org/n7psj3zmd/2zz.jpg)
Checking engine.
Compression
(https://s32.postimg.org/nvac6ti9h/IMG_20160723_151412.jpg)
1zz oil pan
(https://s31.postimg.org/sqfvtdxaz/IMG_20160721_161435.jpg)
Some new stuff
(https://s32.postimg.org/cdm1h3539/IMG_20160728_145532.jpg)
(https://s31.postimg.org/5v3cg1qkb/IMG_20160726_151616.jpg)
Lift bolts
(https://s31.postimg.org/44kbek917/IMG_20160726_151631.jpg)
(https://s10.postimg.org/7bw5rilft/DSC03419.jpg)
Spark plugs
(https://s32.postimg.org/m3c83d0x1/DSC03392.jpg)
Cooler thermostat:
(https://s32.postimg.org/uo5jujb39/IMG_20160725_104829.jpg)
Checking head:
(https://s31.postimg.org/sqbqz4c17/IMG_20160727_141156.jpg)
(https://s31.postimg.org/7hy2hoxkb/IMG_20160727_141204.jpg)
Checking clerances
(https://s32.postimg.org/5lvme8g3p/IMG_20160728_121409.jpg)
(https://s10.postimg.org/b6zju34ll/DSC03412.jpg)
Cleaning engine
(https://s13.postimg.org/dzb656epz/IMG_20160826_160724.jpg)
And checking oil after. Everything OK
(https://s12.postimg.org/ad115zhkd/IMG_20160826_145335.jpg)
(https://s13.postimg.org/posh8o6g7/IMG_20160826_160134.jpg)
Intake insulation
(https://s13.postimg.org/ipmii0lif/IMG_20160830_105518.jpg)
Starting swap
(https://s11.postimg.org/ly5iay6wz/IMG_20160902_151941.jpg)
(https://s11.postimg.org/nelm6tz7n/IMG_20160902_164419.jpg)
(https://s9.postimg.org/fuvhbl1v3/IMG_20160903_122306.jpg)
(https://s21.postimg.org/fkfmxk3xj/IMG_20160903_191113.jpg)
Bemani intercooler
(https://s15.postimg.org/esv4dn4iz/IMG_20160903_154609.jpg)
(https://s15.postimg.org/6bvm2pzu3/IMG_20160903_154620.jpg)
Magnuson MP90
(https://s14.postimg.org/vyi1z0bjl/IMG_20160903_191358.jpg)
(https://s14.postimg.org/51y2qosq9/IMG_20160903_191415.jpg)
(https://s14.postimg.org/uyrr3awdt/IMG_20160903_195003.jpg)
Oil bonnet from 1zz to 2zz
(https://s13.postimg.org/jr5ybpxzb/IMG_20160907_111016.jpg)
Ori clutch
(https://s3.postimg.org/7i7bqyaf7/IMG_20160913_150359_HDR.jpg)
New intercooler setup
(https://s13.postimg.org/y74n45j5j/IMG_20160913_101236_HDR.jpg)
First try
(https://s10.postimg.org/tei3ihmxl/IMG_20160913_130354_HDR.jpg)
Gearboxes
mr2 had c66 + lsd. Corolla c54 no lsd
Both was unmounted and mounted again.
c64 + lsd
(https://s21.postimg.org/fhqr79ijr/DSC03546.jpg)
Differences in shifter shafts
(https://s18.postimg.org/bm0ux6byx/DSC03542.jpg)
So gearbox in mr2 looks like:
Main body c64 + front case, shifter shaft and lsd from c66
(https://s21.postimg.org/7jqvcipbb/DSC03577.jpg)
And step by step
(https://s17.postimg.org/f9tz6mxin/DSC03559.jpg)
(https://s15.postimg.org/hxik81mfv/DSC03551.jpg)
(https://s15.postimg.org/x7iff8hy3/DSC03554.jpg)
(https://s21.postimg.org/8boxxz44n/DSC03566.jpg)
(https://s21.postimg.org/k22vfcwx3/DSC03567.jpg)
(https://s21.postimg.org/ymjya6rvr/DSC03569.jpg)
(https://s21.postimg.org/conhgecvb/DSC03570.jpg)
(https://s21.postimg.org/d2otfzwyv/DSC03571.jpg)
(https://s21.postimg.org/f8j4ai0fb/DSC03573.jpg)
(https://s21.postimg.org/4acg6217r/DSC03575.jpg)
(https://s21.postimg.org/5qnyo744n/DSC03576.jpg)
(https://s15.postimg.org/j2cmdf8wr/DSC03556.jpg)
2zz inside
(https://s22.postimg.org/o1i1ldftd/IMG_20160917_130352_HDR.jpg)
(https://s22.postimg.org/ogxws4r4h/IMG_20160917_170554_HDR.jpg)
And of course 1zz in fake ts:
(https://s18.postimg.org/ayud653vd/IMG_20160917_215038_HDR.jpg)
Again ic
(http://s12.postimg.org/73wzr1tnx/DSC03603.jpg)
Aditional air ventilation rear hood
(http://s17.postimg.org/lb8mj3o5r/DSC03595.jpg)
(http://s17.postimg.org/9an6idgr3/DSC03596.jpg)
(http://s17.postimg.org/40i7r2wi7/DSC03615.jpg)
(http://s9.postimg.org/9396fottb/DSC03669.jpg)
Rear suspension bar was welded. And prepared for more place for sc.
(http://s18.postimg.org/ioxz72id5/DSC03610.jpg)
(http://s18.postimg.org/a7ygw5do9/DSC03612.jpg)
(http://s21.postimg.org/tdwjpy97r/DSC03661.jpg)
Some interior parts:
Alcantara steering wheel
(http://s15.postimg.org/fc180xt57/DSC03643.jpg)
And aditional "clocks" place
(http://s15.postimg.org/o9lxyall7/DSC03651.jpg)
There will be AFR, EGT, oil temp.
(http://s15.postimg.org/69cqtwte3/DSC03654.jpg)
(https://s11.postimg.org/g1e30whcz/DSC03804.jpg)
Rear bumper.
(http://s9.postimg.org/qhe62kiwf/IMG_20160913_120255_HDR.jpg%5B/imgOil%20suction%20pipe4mm%20lower%20and%20biger%20bore%5Bimg%5Dhttps://s16.postimg.org/gtja4s8kl/IMG_20160914_112620_HDR.jpg)
(https://s11.postimg.org/ymyk78hqr/DSC03675.jpg)
1zz oil pan
(https://s9.postimg.org/432x5u927/DSC03679.jpg)
(https://s15.postimg.org/o40d00b7v/DSC03695.jpg)
(https://s15.postimg.org/4ao97axu3/DSC03696.jpg)
(https://s18.postimg.org/3ww7fylrt/DSC03740.jpg)
(https://s14.postimg.org/w7b1b8gyp/DSC03754.jpg)
Exhaust 2x2,5"
(https://s21.postimg.org/jbgavvut3/DSC03724.jpg)
(https://s21.postimg.org/kt1r7fzjr/DSC03726.jpg)
(https://s21.postimg.org/x8yh16svr/DSC03727.jpg)
First run:
m https://www.youtube.com/watch?v=BaXO5OW3d9A (https://www.youtube.com/watch?v=BaXO5OW3d9A) m
Finishing
(https://s17.postimg.org/9wbqio9y7/DSC03819.jpg)
(https://s15.postimg.org/gzd343fkb/DSC03841.jpg)
(https://s9.postimg.org/nzlk3vsxb/DSC03834.jpg)
(https://s21.postimg.org/bnuvajfav/DSC03836.jpg)
(https://s9.postimg.org/bsbkuocb3/DSC03847.jpg)
(https://s9.postimg.org/vp8q2669r/DSC03858.jpg)
(https://s22.postimg.org/4xsjkpic1/DSC03856.jpg)
Geometry
(https://s11.postimg.org/r80qm7dcz/IMG_20161025_122429_HDR.jpg)
Front
(https://s22.postimg.org/ph4r7136p/IMG_20161025_135554_HDR.jpg)
rear
(https://s14.postimg.org/5sdwdgm4h/IMG_20161025_144347_HDR.jpg)
Intercooler fans switch
(http://s14.postimg.org/a9vso6p75/DSC03866.jpg)
Dash
(http://s17.postimg.org/48m0sm0e7/DSC03869.jpg)
Corolla ts with "old" 1zz is running too
(http://s3.postimg.org/6zkrtkkfn/toyota2.jpg)
Im going to reedit this post tommorow.
Great build, must be a lovely car to drive s:) :) s:)
Where did you get the larger bore oil suction pipe, is it a Toyota pipe?
Also, what are the fins on the outside of the sump for?
Heat dissipation, nice idea s:) :) s:)
It's not finished yet. So i cant tell about drive right now.
1. It's toyota suction pipe but with spacer 4mm.
Normally there is smaller hole. We cut it off for better oil flow.
2. Fins are for cooling.
I had some troubles with cooling because nearest race track is technical.
There are alot corners. Im using 90% time 2nd gear.
m http://www.torjastrzab.pl/o-torze,aw38,59 (http://www.torjastrzab.pl/o-torze,aw38,59) m
Awesome build i was toying idea of gt86 seat in mr2 after seeing how good these look in mr2 im now on look out. Also does gt86 steering wheel fit mr2,
Wow that's a full-on build. Looking forward to the results.
What is it with yoy Polish people?
"this isn't optimal... Get the angle grinder and welder! "
I love it. That's proper car modification
Really like the seat rail modification!
Could you provide more details on this? Do you have a template for cutting?
Nice work. Congratulations on getting your ideas to reality.
@jvanzyl
Belive me You dont need tutorial! Its very simple.
You need driller and welder only.
1. Drill tack welds in rails to detach mounts.
2. Screw mounts in orginal places.
3. FIt gt86 seats to mounts.
4. Weld!
5. Well done.
Now all you need to do is learn to weld s:) :) s:)
@shnazzle
You can use paperclips and bubble gum instead.
@MR TWO
Abandoned ideas:
Splitter
Diffuser
Flat floor
Naca duct
Excellent work, wabbitkilla approves s:D :D s:D
Quote from: "Wabbitkilla"Excellent work, wabbitkilla approves s:D :D s:D
Nic is happy we can all rest easy.
Well done.
great build always like a home built stuff, some nice work, i need to learn to weld!
cheers tommy
Quote from: "shnazzle"Now all you need to do is learn to weld s:) :) s:)
LOL - ! The wife is ok with me doing the course.. the year AFTER next! talk about kicking the can down the road...
@Culmen - thank you for the simple explanation! :-) :-) :-)
Great build. Really like the exhaust
REALLY like what's you've done with your '2. Want!
Power to weight ratio must be pretty impressive?!
great build looks amazing
Just wow bet it's so much fun!
(https://s22.postimg.org/firzatk8x/IMG_20161104_180239.jpg)
We finished intake.
Now ECU time.
m https://www.youtube.com/watch?v=h0nGMzK ... e=youtu.be (https://www.youtube.com/watch?v=h0nGMzKJ20Q&feature=youtu.be) m
We finished project already.
There was some trouble but most of them solved.
Stock ECU, stock injectors s;) ;) s;)
High range will be better but we didnt remove that 1" part of intake before air filter,
and second think intake blown during dyno.
Noting serious silicon tube before IC.
WOW! More than 300bhp! Would be amazing to see what that car could do a 1/4 mile in?
Wrong just 233hp@7500. Suppose a litle bit more on the top.
There was alot problems on dyno. We didnt check after "repair" intake.
Not tested yet.
Just going track 19.03
What an amazing build. I just recently left you a YouTube comment and thank you for the reply. Do you have any of your build on Instagram? If so check out mine at TrackKingRacing ... Also have a build over at Spyderchat under TKR GT300 2zzgte build .
Sent from my XT1585 using Tapatalk
Old exhaust last about 1000km
Rebiuld one:
m https://www.youtube.com/watch?v=lbzKpU40bgk (https://www.youtube.com/watch?v=lbzKpU40bgk) m
2nd & 3rd gear cceleration:
m https://www.youtube.com/watch?v=odLDMEshkCw (https://www.youtube.com/watch?v=odLDMEshkCw) m
Silencers
[/img]https://s29.postimg.org/ppglurciv/IMG_20170322_164051.jpg[/url]
(https://s23.postimg.org/ors9lw3or/IMG_20170322_164108.jpg)
Car is used by my gf as daily drive so silencers are a must!
Very nice mate
Awesome build, excellent work. s:bowdown: :bowdown: s:bowdown: Where did you get the main instrument dials?
Thx!
Soon first trackday tests.
@SDB278
You mean dash?
m http://moman.pl/eu/ (http://moman.pl/eu/) m
The only problem is stock dash is not prepared for 8krpm+.
Yes dash. Many thanks!! s:) :) s:)
Awesome build culmen!
Could you explain how on earth can you run on stock 2zz ECU? And with stock injectors?
Quote from: "inside"Awesome build culmen!
You can do it on a stock 1mz with the trd charger at 4psi.
There is also a 2gr i know of doing the same thing.
Stock celica 2zz ecu is running on autoadaptation.
Its very simmilar ecu to 1zz ecu (propably other too)
If You are intrested about autoadaptation I can write some about behavior.
And about fuel injectors.
They are stock but we increased fuel pressure.
If you know a lot about the Toyota ecu auto adaptation, can I ask you to explain in the LTFT Emanage thread. Please?
l viewtopic.php?t=57975 (http://www.mr2roc.org/phpBB3/viewtopic.php?t=57975) l
Or
l viewtopic.php?t=54259 (http://www.mr2roc.org/phpBB3/viewtopic.php?t=54259) l
Quote from: "culmen"If You are intrested about autoadaptation I can write some about behavior.
Yes please do, I'm very interested in this!
Would you say this is easier to do than e.g. custom tuning on PFC?
Also would you say this is more / same or less reliable than custom map on standalone ecu?
Im back s;) ;) s;)
About autoadaptation.
It seems raliable.
Corolla did over 150k km on that setup. And i get no engine fault in service history.
Mr did few kkm already (2 track days and over 300km on tracks already)
and almost no bad signs.
At 1st trackdays "Kielce 4nano time attack" was very hot and i had some problems with temperature water/oil
I changed front radiator to mishimoto. Problem solved water dont exced 90c already and oil temperature drops too.
On next TD "Autodrom Jastrząb" only twice oil reach over 120c (about 1km slower and temp drops to 100c)
(http://www.forum.alfaholicy.org/images/imported/2017/07/50.jpg)
(http://www.forum.alfaholicy.org/images/imported/2017/07/51.jpg)
I want flames!!!
On Kielce trackday i had problem with fuel.
On 1/4 there was not enough fuel in corners and afr goes low.
Second problem. After 2 sessions i run out od front brake pads.
I was to "hungry" and i was pushing hard still s;) ;) s;)
(https://lh3.googleusercontent.com/SWAcmkWdXFlb9XJXVFp5mF_dIdlZfk2LynTWwclgORtM0EJIyxbkgNYMGwfkYeUTOQdz3J8swXviGGhtKs2EtAvquLFx6jCJsJ-pUTe4g40nUd_0AN9gRJ5pI5ws0Zzvkgy3uYLGMMjWs3UUBLwGnEmr3kXYXta0mBklg3k4WAJWMuRG87VXooJ0UA2UqK7N8XFfq9Nul4fjtBKpu9pWr99Wm0Rp1R3Qlcgs2S9TbJGNX017s4PqgmsRO8aiCy0TexDKuOR0spPy3V8wpw6eYuKYX-HBROOlmJgOAgsJTXTng37-PaqldOTHB5Lp5DjY3xMki09-3G_wFrJTDVFXTKpuNrM-1c5EgIFV2r992CVfeEosGepRhPrjKrAEh4yIUNfNFe04Fncf78bgdZKIHS3tSaGy1TEgpo4KF-1tzAxlzjdIIb-DpI4qKBHE-eBvzYJuP67ybPU99AI0Dzs8HAqrvZjmFwjE-M2aR6g66WxgLm_cWZyuMvH02v0aUnvnXBLwlU9ym77llAIkSZdtltdKIgRD5OjM3oicAGEHf8rc9jXlNVK7xx0NvNfS4bSALd433A5eD6BIVZCIns3UmEwqqN9bDvLSvmrI9g3rkgc7XIrC_g=w748-h1331-no)
Ordered again front ferrodo ds2500 rear yellow EBC
I think fuel starvation at that fuel level is normal, I get it on roundabouts on my way home from work. Maybe you can sort a swirl pot? With your fabrication skills it can't be too hard! The car looks great so keep on showing us your efforts!
@jonty
Most tracks im running has fuel station in about 5km.
Another event finished without big problems. 4nano Koszalin time attack
(Just fuel starvation and raising oil temp)
Im trying to not drive when temp reach 120c. I know its super afe temp.
This time i used yokohama a048 tyres on OZ Superleggera rims.
Front 205/50 r15 soft
Rear 225/50 r15 medium ( left tyre scrubs from fime to time on bumps.
(https://lh3.googleusercontent.com/C6oS_oWJGNdtHfZOBxJrnxm0Dfavvp3-7AgMkg-U_jzzFkj5rhuJQb6p_g3ihk0df7F2XqDj8WZ29pEc9Q9pclDl2krd_WhOCc1Oq3n7npfBXdh1xR12BxLZSS7ZFV8Gy0R0H1PWEMbEiPK4GexoA0DoA4wojZ8lqGUuT6Qwgnb7KL4zmMXxmN9FwC3x31bXFXNrcUaPxnEOv7sCWcl_6CPDUmKjo9tyRfFb7CqkHbBsrUtzNtU6rUsrJo0M8_vEZ_dKdJa7wlMIBLcRe6vtyOj3dhXxgF_UaGVmWiaffSPI2SrAv92YqsRlRPvH6Aq-apkPEMhNN9bx8PU1wIRMtD_jVw1-T8RwrK3achiye-2H0Y9-AMVl5MpnyKZXb5GFFLCkUzV2nX27U2WwesozcaxGRj-4olZnbLd-VxbrClIvcXyzvzaWBTlJV-sXQ0UQ9Im-L7W0maoiMTS3HvI1HjHGaU_JHBSultJvx6fqTzn0v72MzsHWABenBLD9DUAK6qbhddbsH2RSNmAuRcYLxp8oh0n0iw0Z6RoAmDnFoAYOQ9iU4BtdGY4HT3LFMA6-By8HxHTIuasbe3GgeyKvKrahrAsav-CwGdmXccrCRYRtKMQxbw=w2371-h1331-no)
And fotos from Motopark Koszalin
(http://seat-racing.pl/foto/_data/i/upload/2017/07/31/20170731113708-0d7cbdf9-la.jpg)
(http://seat-racing.pl/foto/_data/i/upload/2017/07/31/20170731113702-52024669-la.jpg)
(http://seat-racing.pl/foto/_data/i/upload/2017/07/31/20170731113006-611236b3-la.jpg)
(http://seat-racing.pl/foto/_data/i/upload/2017/07/31/20170731105137-18aafec4-la.jpg)
More photos here:
m http://seat-racing.pl/foto/index.php?/category/44 (http://seat-racing.pl/foto/index.php?/category/44) m
(https://s26.postimg.org/qg58br3bd/Kielce_4nano.jpg)
(https://s1.postimg.org/3nlou0ehjj/DSC08320.jpg)
(https://s1.postimg.org/4y1dehnyzz/DSC08341.jpg)
Car survived another trackday.
Kielce circuit.
Rainy/wet conditions makes that place slippy as ice.
There are 2 or 3 different asphalt with various grip.
I'm going another track day this sunday.
Love your car, driving that on track looks like fun. And the flames in your other pics is like Smok Wawelski from Kraków!!
Another trackday survived s;) ;) s;)
(https://s1.postimg.org/20dc5inylr/jaszczomb_2.jpg)
Car is still reliable. This one without any problems.
This year i did total 9kkm and about trackdays 700km.
This time i was 7th
(https://s1.postimg.org/8ef6my6n7z/1.10.2017.jpg)
Place 1 & 2 are errors.
It's sacond to last session not fastest.
I was very tired already and few times failed gear change.
After 10min tires were overheated.
[youtube:29x6x04c]S1tEU4fO2D0[/youtube:29x6x04c]
New race year has begun!
https://www.youtube.com/watch?v=fKuGVnd52FY&feature=share
https://www.facebook.com/rajterkrzysztof/photos/a.435092106951599.1073741854.327472071046937/435099323617544/?type=3&theater
(https://scontent-frx5-1.xx.fbcdn.net/v/t1.0-9/29597587_1801290200175039_6300987392209226960_n.png?_nc_cat=0&oh=0c01e172ceeff36f86bf41597abc720a&oe=5B312A95)
After winter i had some problems this time.
Some problems with 3rd gear.
And i was not able to remove sillencers!
I remove screws and i shot left on track.
Another problems was tyres.
Wheather forecast says 0c-5c and wet conditions.
I choose toyo r1r. I killed them on 1st session :-\
They are goot for daily use but they are not enough for dry track in 15c.
(https://s31.postimg.org/ehiyrwoez/IMG_20180325_150549_1.jpg)
Next track Pixers ring 15 april
Stay tunned!
Finished another 2 race / Time attack rounds.
Pixers ring but i dont have any foto. And any good results too ;)
But next round was much more succes full.
I bought tyres.
(https://lh3.googleusercontent.com/rYudJtaqDNevnVDzsIG5gF94eR1l7P2_X4ygRt-cYpnKANkQYK0aOy6HYqs3ReHILHCMJYlVGJGOmhklrMKjlkwcSPt3sk4Mm43dBIqVAFDCwDHiH9Rj9NbSjEWIXmNEjTAjsGspvI9kPy70LWC63nDnRcAu5E5zLJB9OUz-ayfU5jvhFEw_WWPsN3ABWDAx4TqH4LYQ8h0hDKuYK6yIZ3UNGi6w-pmkBbEmLJwFndMcQ6XgJP1XuHJFAw0uIQVstIdpQlgqI6xXj9mLwJZl3eG079jRU29qq5FtQ74EnClmw8lRWuZkPyV1Mu9M3ER54HlfHD-wbtL1TRwoMDmX5V-zN7o20mxb3UdU0UGnRIzxGo5uTOfeYqaINvtR-j29au6E1_s86JVMU40oQW4bWpTU0ySDGm2CKpuKT2-N_WRMW7yj1dt5jkgUvuRLBYv_EMNSM5BRS4uVeuZ2UelmOlPrce4mU53c1aN3WU5DDOrlnUG1BSbfnrUsZ5eXi_SuEGhx1EaG4ExXbWzRjHqp_CZKt7R9RUD4XTERa1nkl8837AreR_sHktIhSVY1EjKvpuB_NicAtKgQ_Uw7n31BzZQ5XpP4Ou_Q=w540-h720-no)
Front michellin 19/57 r15 Medium
Rear dunlop 205/555 r15 Medium
And goes autodrom Jastrząb track for Avalon Extreme race Day.
Then weather changed :D
https://youtu.be/jJrWHYwXbeU
(https://lh3.googleusercontent.com/W1WzOFX7LLIFqObpQgOdTz5iMQfB_DwLoLmdI0VF4CyOPF2CO9HM1IHzxueOxsoVs6SJ5iamCOS1KUiyIIDvB5swWKkJvSoYF2DgrBWtofTklSJDb2f_jxDQ0110zVR82BsajPt7rWIOvGaB7tFZfMx8ChDRoxIBOeMvPgrn34hn3EtNEe5gh7iSyQqGxDwP6zxZ7XRZQhTPmC47c9ZckSG1vIZnfeBIoPXjna6spJH4q1466MHTD6lEQwgkOIV0VtWe3mova6GJmm4NXVsNe7r0-ddUy6oIIJge5kM5ryrzISmzB-w0vlGWztivy0dYFf9xtt2fiaWp9aDRwd5w1EwUkD7uzJVJd_Max9Ru_uq3tETHW9pGrMZG-LmaLYkAplSzBpXP-IoAW-w0mJaks6WwGBOnxxCOF4liWVa6SoHjlK8EssA69Zkm-k8DmvSzc4ZpnAR7o4YvYxfjELy6gyjr7CgIq3PGhHLo40KwdocUa_Lcvn4tPZrAVEMYH5qjOAYJ1ukh_sEoj4sY7_iLswxzjqezalhaQ--G_nnIizk4hLBkcGZv95d3HgXW0hhV0dpznEr3Ok8UBSZfmtbmHp55LgQKK3OU=w258-h172-no)
(https://lh3.googleusercontent.com/j9DTAUlI1cqexrno-ObhnjMARar5mBI8FyAJvn4Qv5t7Cuo60LHvl9t6JwOkcCVNmlRTK7K1tMpOkb-1sFjUMVypRKB5lX3E1drXhkm9ZhOr6nczlng7v82T0RVrG9u7_0Xfjd2BSbMyQOq6ImnJymVi8Z-AoY4fsy7aXpKwuqbMqSTVr9bz9jUWLrNsDgYueuTo-vuHIqtTOxGyKzfF4rkC0diIrIGSXqWXrmBiye2XimdM92h2L-nHPkpx4wW6SSoqzj8lZ8mRqDyLwbKuctFbWUJphsZxb_-tZPywtU8bILAR_42nlyrveFXu12NIkjVVeiSGb3pdnpcBj62HTzkr8y5bODlK2i-7UrsCbBE9PZHVHqZHF5sIJQPKsYrn3L9cMvKKM1r9XJJz0juIv0QMxDjUiohfZ23eKoGahxjZ2TR4TzXpizvecw80HX5RLBlHvICErr9QUnyTHkImPNhxZrXI-UQPqDAC4ASuKZm7sjZ-Xmgv84A6Cym70AD2OQ6aY2-Vfph5TUqK6Qe3lY7At6yQ76FOFfLqKYIHUgMc6WahXKY2Zo4Se_rjWHlLp8JmK3nm10w8kNQbWIrW-4Y41yy1XzHW=w258-h172-no)
Finished 2nd in class because mine last run was on semi wet conditions.
Finished because i choose 1st gear instead of 3rd.
Engine is working but making strange noise. Need to repair.
Still loving the car
https://youtu.be/cqa99PA9zvQ
jaworjawor as passenger ;)
She goes well!!
Some another event.
Finished 15 in overall.
https://rajd.internetowy.pl/results/25
And free ride with passenger after.
https://www.youtube.com/watch?v=CSXrykUkxGs
