how can u remove the front headlights say for changing a bulb
and how did the yellow '2 colour coded his headlights?
i heard that u can put the headlight in the oven @ about gas mark 5 for 5 min and this will melt the seal so u can remove the clear plastic from the back part then spray it and re heat it to seal it back s:?: :?: s:?: (some guy done it the the FTO)
Quote from: "duongs"how can u remove the front headlights say for changing a bulb.
You dont need to. You remove the black plastic under the bonnet as mentioned in the hand book. Not the best solution IMHO.
Yes you can bake the lights, but not to change the lamp.
Quote from: "victor"You remove the black plastic under the bonnet as mentioned in the hand book. Not the best solution IMHO.
so u need to order new pins to replace/secure the black plastic?
Just push the smaller cirlce in the center of the pin in with the tip of a screwdriver, about 2-3mm, it will click and become loose, then just pull the whole pin out in one peace.
Reset the pin by pushing them back up and half way out the top, then push the whole pin into the hole and click the center back in s:) :) s:) , sorry i have not got any pics to hand.
You can change the bulb's by just undoing the front coners and lifting the plastic up, its a pain, but saves on removing the whole cover.
Andy
so after removing the black plastic can i remove the headlight just by undoing the couple of screw?
What are you wanting to do? Remove the headlight or remove a bulb?
changing the bulb,
but maybe colour code the headlight aswel
changing bulbs can be done without removeal of the headligth but is a little tight! s:cry: :cry: s:cry:
Toi remove the headligth you have to remove the front bumper but i havent got a linbk for that it is pretty easy but im sure some one will post a link to how to remove it for you s:wink: :wink: s:wink:
Quote from: "Buster"Toi remove the headligth you have to remove the front bumper but i havent got a linbk for that it is pretty easy but im sure some one will post a link to how to remove it for you s:wink: :wink: s:wink:
Spyder magazine have an articule covering bumper removal (http://www.spydermagazine.com/2001/Nov/bumper/removebumper.htm), I've tried it and it's not exactly hard.
Quote from: "phil4"Spyder magazine have an articule covering bumper removal (http://www.spydermagazine.com/2001/Nov/bumper/removebumper.htm), I've tried it and it's not exactly hard.
the last time i tryed to remove the bumper on the fto i left a big gap on both side where the bumper meet the front wing s:oops: :oops: s:oops:
but i think colour coding the lights look wicked so maybe try again lets hope this time i don't mess up
And you weren't left with any screws? The ones that govern the wing bumper join seem to the be the two under the wheel well cover, if that's any help when you come to tighten them.
Quote from: "phil4"And you weren't left with any screws? The ones that govern the wing bumper join seem to the be the two under the wheel well cover, if that's any help when you come to tighten them.
sold the car with the big gaps s:twisted: :twisted: s:twisted:
Quote from: "duongs"but i think colour coding the lights look wicked so maybe try again lets hope this time i don't mess up
Well mine are done & it improves the 2 100% IMHO.
Pics to appear soon of completed 2 & lights on their own.
Quote from: "SilverMSD2"Well mine are done & it improves the 2 100% IMHO.
so how do u reseal the cover to make sure water cant get in?
