So I'm going to mock up this:
(https://i.ibb.co/xjxPdHn/EAB04-FF1-34-B0-459-B-A8-B1-4-BF065-D801-B1.jpg) (https://ibb.co/xjxPdHn)
Probably out of some kind of plastic plumbing pipe to start with, and then I'm going to do it out of stainless.
Can anyone recommend a place to get stainless from for making exhausts?
And where on Earth do you buy flanges from? Tempted to cut up the old stock manifold..
Stainless steel prices have gone through the roof recently, if you purchase from a stockholder, be prepared, best bet is if you have a local fabricator who may have some "off cuts" going cheep
As for the flanges, you can get them from an exhaust fitting outlet, failing that, get them laser cut
Rob
I am not aware what turbo you are going to use but get some vbands and use some slip on clips. Going to be way easier. Are you sure you want that tight bend?
Quote from: Zxrob on April 8, 2022, 11:04Stainless steel prices have gone through the roof recently, if you purchase from a stockholder, be prepared, best bet is if you have a local fabricator who may have some "off cuts" going cheep
Rob
Thanks Rob
Quote from: Nvy on April 8, 2022, 11:09I am not aware what turbo you are going to use but get some vbands and use some slip on clips. Going to be way easier. Are you sure you want that tight bend?
Gtx2554r
Yes the intention is to use v bands.
That down pipe is what is in the TTE turbo. I'm aiming to use the stock mid pipe location which will hopefully mean more faff now for way less faff later.
Profusion -all the stainless exhaust bits you could want.
https://www.profusionexhausts.com/ (https://www.profusionexhausts.com/)
Its better to go fully custom if you ask me. Mid pipe is mega small, you would want 2.5 and bigger. The turbo will muffle half of the sound.
Try TB Developments for the flanges, not the cheapest but he "knows" MR2s.
@jvanzyl For what it's worth. If I can measure anything for you, off of mine, let me know.
Quote from: Nvy on April 8, 2022, 16:58Its better to go fully custom if you ask me. Mid pipe is mega small, you would want 2.5 and bigger. The turbo will muffle half of the sound.
I'll see how it goes... the idea is to be able to replace the cat easily if needed.
Quote from: Call the midlife! on April 8, 2022, 17:13Try TB Developments for the flanges, not the cheapest but he "knows" MR2s.
Cool I'll have a look
Quote from: Carolyn on April 8, 2022, 16:51Profusion -all the stainless exhaust bits you could want.
Thanks for this - I'll have a look
Quote from: Ardent on April 8, 2022, 20:41@jvanzyl
Thanks Jason, much appreciated.
Having a browse of the site Carolyn provided:
the u-bed
https://www.profusionexhausts.com/180-degree-76mm-1-5d-mandrel-exhaust-bend-t304-stainless-steel-long-legs/
Some bits to create the curve:
https://www.profusionexhausts.com/3-76mm-pie-cut-90-degree-304-stainless-steel-exhaust-elbow-bend/
v-band kit:
https://www.profusionexhausts.com/3-inch-76mm-profusion-304-stainless-steel-v-band-clamp-kit-m-f-quick-release/
will need to investigate how to make the 1 into 2 piece..
In the event I decide to go custom from Turbo to the exhaust:
High flow cat
https://www.profusionexhausts.com/3-76mm-magnaflow-universal-high-flow-sports-cat-200-cell-cpsi-59959/
