The Workshop => Maintenance, Problems & Troubleshooting => Topic started by: gazza1286 on December 13, 2022, 16:34
Title: Power Steering failure
Post by: gazza1286 on December 13, 2022, 16:34
Hi my 2006 roadster has a leak in one of the small pipes running from the steering shaft to the rack. I am sourcing replacements for these.
I am assuming that the system is totally empty as there isn't any liquid visible in the reservoir. The car was driving perfectly up until I had to return home yesterday when the steering was extremely heavy. luckily I was less than a mle from home, so no damage to the pump I expect.
Toyota want £45 for one litre!! I do no believe that any alternative fluid can be used. What is the capacity of the system? Is one litre enough?
Title: Re: Power Steering failure
Post by: Topdownman on December 13, 2022, 16:45
There has been some previous discussion on this;
https://www.mr2roc.org/index.php?topic=60991.0
I have Ravenol in one of my cars and I am not aware of any problems from this a few years on.
I believe that 1 ltr would be enough to fill it but you may want more if you are going to flush it out before refilling.
Post by: Carolyn on December 13, 2022, 17:46
I use Ravenol as well.  No problems.
Post by: Gaz mr-s on December 13, 2022, 18:20
This is also correct, & cheaper than Ravenol.
https://www.ebay.co.uk/itm/203507407679?hash=item2f61fc9b3f:g:HtoAAOSwzU9g2Zae&amdata=enc%3AAQAHAAAA4Iiks2WG%2B%2FRWw7wsWBiX4J%2BeF6sRx4%2BO9z40UqzJHWaq0OOtusCoLG%2FrtCJvQuz2HtsumlBOaOSeHUqiVHgz3lCdIw2UICceBM4WIVZ9%2FwlZMMFUE2ezH46tGeKGYjfbxHp232poGTLz0JPsAawaY7XeUGFrwV0A1TUtiCj3raJUOoiqoXpsqTxTgJ3jYMr%2B8iGUInCsnUT3R6zwO%2B%2F7tYJ55Wt0MsKjZebY0EfV856e66aP0eERsLbVRJNt4J5B5NI6wHtkcb68RkwA33jQAfb0BOkGyZf1vu%2Bx4Mu9LP%2Ba%7Ctkp%3ABk9SR57opcuhYQ
Post by: Joesson on December 13, 2022, 19:18
My reading of Ravenol mentions Toyota in their specification and  is priced at £14.95/L. + Delivery.
https://www.ravenol-direct.uk/ravenol-e-psf-power-steering-fluid-1-litre.html
The Mannol is offered at £37.99/2L + Delivery at £5.70.
I bought 2x 1 L of Ravenol, I believe one L would refill, can't be certain as I flushed the dirty reside from the system and took the pump out of the casing to clean that, I then refilled and used all of the two bottles.
Otherwise TCB I believe offer Toyota fluid, probably at less than Toyota price, but you will be paying also for delivery.
Post by: Gaz mr-s on December 13, 2022, 19:52
Quote from: Joesson on December 13, 2022, 19:18The Mannol is offered at £37.99/2L + Delivery at £5.70.
The price in my link is £32.29 for 2l.  Postage is free.
The Ravenol is over £21 for 1 litre.
Post by: Joesson on December 13, 2022, 20:19
Quote from: Gaz mr-s on December 13, 2022, 19:52The price in my link is £32.29 for 2l.  Postage is free.
Sorry, I misread the Mannol ad.
It is £37.99 and postage is free on my opening the link you posted ( the £5.70 is a discount for something or other, and I did got to Specsave!!
But, the base price is lower in your reading of your link at £32.99/ 2L .
The Ravenol is at £14.95 / 1L on my reading of my link.
I am based in Warwickshire that is very much in the Midlands!
Someone will know why that is/ could be, I don't!
Post by: Gaz mr-s on December 13, 2022, 20:27
Quote from: Joesson on December 13, 2022, 20:19The Ravenol is at £14.95 / 1L on my reading of my link.
+ £6.75 postage
Post by: Bossworld on December 13, 2022, 20:48
Needs to be EHSF (electro hydraulic)
Total Fluide DA is also a cheaper option, changed my old car out (and the pipes) back in ~2017 and no issues since. https://www.mr2roc.org/index.php?topic=66735.0
Post by: Joesson on December 13, 2022, 23:16
Quote from: Gaz mr-s on December 13, 2022, 20:27+ £6.75 postage
So,
£36.65 for Ravenol for me.£42.00 or £48.75 for you.
£37.99 for Mannol for me. £32.99 for you
Not so much difference in what we spend on our cars but Really don't know why there is that difference in pricing for the same products but viewed on a website from a different region.
Post by: Gaz mr-s on December 14, 2022, 08:50
Quote from: Joesson on December 13, 2022, 23:16So,
The ebay price is UK wide, unless a shipper has different rates for northern Scotland or the Isles.
Post by: Beachbum957 on December 14, 2022, 11:31
Another option common in the US is Nissan 999MP-EPSF00P.  Don't know cost or availability on your side of the pond, but it works fine.
Post by: gazza1286 on December 14, 2022, 12:54
I decided to just get the Toyota fluid from the dealer as it will be available from tomorrow with the pipes I ordered. These were the two thinner pipes which bolt directly onto the rack. One was the source of the leak and the other looked a bit crusty.
I couldn't find any after-market replacements and a repair by a local hydraulics company would have been approx £50. They would have cobbled flexis between the original ends. Toyota want £71 and they come with new o-rings.
For those who want to know Toyota confirmed that the system capacity is 0.6 litre.
Post by: J88TEO on December 14, 2022, 14:57
Check the PS rack mountings are not cracked...
