There is a slight scraping noise coming from the engine bay, not sure where. When the car is ticking over, can't really hear it when you in the car, but when you get out you can, so I know it makes the noise when it's in neutral, but not too sure if it does when it's in gear, could it be the release bearing from the clutch?? (But then I should only be hearing it when they clutch is engaged?)
Any ideas would be much appreciated?
It might just be my sensitive ears, now that I have got to know the car a bit more.
