Viet 2zz project
Started by Vietts, May 7, 2014, 10:31
Vietts
#50
Quote from: "Meeerrrk"Are you leaving the front arb standard?
Where did you get the your read bar from?
Hey bud
For the front I'm currently got the whiteline 22 mm bar installed and set to soft. Brought from camskills.
The rear was brought from dc performance
Thanks, I'd never seen the UR ones for sale I'll check it out.
mr-ed_smt
#52
What's ball joint sockets are you putting in those wishbones Vietts, and how?
Vietts
#53
Wishbone project finish! Pictures of it is above  s:) :) s:)
Quote from: "mr-ed_smt"What's ball joint sockets are you putting in those wishbones Vietts, and how?
I use a blueprint ball joint/socket mate. You can get them from any auto store for about £18. Or you can be ghetto and find a 27mm long socket and give it a go? Ahhaha ohyeh you'll need them pressed in too  s:) :) s:)
Vietts
#54
19mm rear ARB installed
Undo both side
5 Allen key
17 mm spanner
Then the main bracket bolts 14mm
Wiggle it out and take off the bracket from the bush as you'll be using it on your new setup
Driver side. Notice the angle of the end link?
Now do everything again in a reverse order on your new ARB
All done  s:) :) s:)  now it's play time!
Nice and quick providing your drop links aren't seized!
How does it feel?
Vietts
#56
Just got back from a quick test run.... hahaha its a new drop link now as i had to cut away the old set that was on there for many many moon. Now all nuts and bolts are greased so no more trouble in the future.... hopefully
all I can say is OMfG!!! I can't believe how much it improved. The back end feel so much more sharper and less sluggish. It actually follow the front end now if you know what I mean lol. Don't know why I didnt get this before lol.  s:bounce: :bounce: s:bounce:    s:bounce: :bounce: s:bounce:    s:bounce: :bounce: s:bounce:
snap3
#57
Where did u get em?
To get a even better performance out of the ARB you need thicker drop links! The standard OEM are to thin and flexible .
Vietts
#59
Hmmm thanks for the heads up. I'll look into it  s:) :) s:)
Be wary of "upgrading" the droplinks.
The standard ones may look weedy, but they do a very good job.
The upgrade ones use pillowball  type joints which don't survive our weather or our roads well.
The main benefit of the standard droplinks is the weather proofed balljoints which rarely fail as opposed to the "upgrades".
Vietts
#61
Thanks for the info
My oem end link only done 3k miles so I'm just gonna use/test them until they start to give up. No point replacing them if there not broken  s;) ;) s;)
Vietts
#62
Update
The final engine mount went in today.
Vietts
#63
Remade my exhaust yesterday for track days. Hopefully this time round they let me stay on for longer lol
Old set up
2.5 inch all the way ( no cat )
98 - 102 DB
New setup ( custom made massive silencer box )
2.5 inch decat
2.25 inch pipe
2.25 inch silencer insert
Smaller oval tail pipe
on normal drive it's very subtle. Nice deep humble. LIFT is a different note lol. You really hear it open up. Will try and get a short video clip once I get my charge pipe back
Vietts
#64
Installed my front lower control arms yesterday. Everything went smoothly until one of the the driver side 17 mm bolt snap off! Now that was fun taking out.... all in it took me about 4 hours to do the both side.
Here she is all done
Took it for a short blast straight after but it do need another wheel alignment again. So far turn-in is alot more responsive compare to the knackered oem bush I had on there. It feel like a giant gokart  s:D :D s:D  can't wait to bring it on track next year
Vietts
#65
Got my wheel alignment done today by Tyres Shop in Chingford London
5 stars services! They even got a Xbox in the waiting room! Fun while you wait can't get any better. I will defo be recommending this place to everyone who is serious about handling.
upon arrival they got me on the ramp straight away as promised
Before and after
This time round I wanted more camber for better cornering speed.
I would like to say a massive thanks for Barry and Gary at Tyres Shop for the awesome job they have done.  s:bounce: :bounce: s:bounce:
Vietts
#66
Small update
I just placed an order for my half rear cage from Protection & Performance. Can't wait til this badboi arrive. Will update more when she come
Sadlebag
#67
Is this the engine out your old yellow 7 or have I got the completly wrong person?
Quote from: "Vietts"Small update
Nice one, black? Still waiting to get mine fitted
Vietts
#69
Quote from: "Sadlebag"Is this the engine out your old yellow 7 or have I got the completly wrong person?
Hello buddy! Long time. Sadly no   s:cry: :cry: s:cry:  the beast is in my kitchen looking pretty lol
Vietts
#70
Yes black. I don't want anything too in your face lol have you already book in with someone to get the feet welded?
IO2
#71
Hi veitt
Is that tyre shop any good? I go pass chingford everyday to work and soon will need my alignment done once Ive upgrade my suspension setup
One of my mates has offered to but he is busy setting up a new business so it won't be for a while, I'm in no rush though
Sadlebag
#73
So you have two 2zz engines... Well that's just greedy! I've been looking into the half cages to as they provide a good base for harnesses! Think I did see you at the pod last year, I have a pic on my laptop which I'll upload for you when I get back home!
Sadlebag
#74
