Blue PFL V8 conversion
8thumpers
Nearside rear hub removal was a lot easier. Often the way when we have learned the technique previously!
The balljoint puller kit had to be utilised on the tie rod end this side.
As before the abs sensor is the worst thing to remove - seized good and propper!
8thumpers
Started to design the rear hub carrier....
8thumpers
Had a play on the cad to draw up a carrier design. The Audi hub will bolt to this "donut" then the suspension arm brackets can be fitted from a jig off the original Toyota hub.
8thumpers
Quote from: "8thumpers"Had a play on the cad to draw up a carrier design. The Audi hub will bolt to this "donut" then the suspension arm brackets can be fitted from a jig off the original Toyota hub.
Can't load video......
8thumpers
Cad design
Wow man- this is brilliant! I especially appreciate the photos of you taking apart the tie rod stage by stage as I've not seen the before...
8thumpers
This is the Audi OB1 "Star Wars" gearbox.
Think about it....
I've offered it up for the first time today and it is shorter than I 1st thought... the rear should just sit inside the bumper line.
Of course the final location will be determined by the engine/ firewall position.
8thumpers
You can see how the driveshafts work in these new generation boxes. The diff is located alongside the flywheel meaning a much shorter total package length from front of engine to c/l of output shafts.
A quick track measure between mr2 and Audi shows they are very close on width between driveshaft ends... maybe 30mm or so difference.
manos3003
Good work Otto!
Keep us updated, with as much detail as possible. Interested to see how you can shoehorn this huge lump in that small car.
8thumpers
Quote from: "manos3003"Good work Otto!
Cheers mate!
Well it looks like it might just fit.....
manos3003
Curious about the driveshafts. Is the offset angle that big that might change the torsional vibrations?
For plain-english-peeps: In a hard acceleration, if the driveshafts are at a large offset, will that cause the car to shake horribly, or worse (which I dread to think, let alone mention)
8thumpers
#36
Quote from: "manos3003"Curious about the driveshafts. Is the offset angle that big that might change the torsional vibrations?
I don't think the shafts will be offset at all... at least that is the plan.
Interestingly, on a Boxster they are quite offset from hub to gearbox.
Ill know more when the old engine etc is out and I can make an initial offering up in the bay.
Off the fabricator now to see about these hubs.....
greybeardgt
Offset driveshafts on porkies Ithink you will find the Boxster has drive shafts in line with the rear hubs (the engine is in front) its the 911 (engine behind rear hubs) that has the drive shafts offset forward. The first 911 2ltr had straight driveshafts but had a habit of going through hedges backwards this was cuured? by moving the eng/box forward thus offset shafts! no problem with 911s.transmitting power through there shafts cheers grey beardgt
8thumpers
Quote from: "greybeardgt"Offset driveshafts on porkies Ithink you will find the Boxster has drive shafts in line with the rear hubs (the engine is in front) its the 911 (engine behind rear hubs) that has the drive shafts offset forward. The first 911 2ltr had straight driveshafts but had a habit of going through hedges backwards this was cuured? by moving the eng/box forward thus offset shafts! no problem with 911s.transmitting power through there shafts cheers grey beardgt
Thanx for the clarification!
No probs with that for us in the 2s  s:) :) s:)
8thumpers
After setting up the driveshafts and hubs from both Audi and MR2 gearboxes, I have determined that the hub wheel face will project out 56mm each side, from the Toyota position once the star wars box is in.
I had anticipated it would be wider and assumed I'd need wider bodywork to cover it.....
toyofan
#40
Hi, cool project!!!
Regarding the rear hubs, have you considered having the audi hub machined down to a normal Bearing (like the Mr2 has as stock) and just mount it in the hub as stock?
From the picture it looks like the inner hole in the bearing is big, but the outer diameter looks small.
Or maybe you can use find another bearing with the audi inner diameter, and Toyota outer diameter.
Just a tip, dont know if it is even possible, but will sure make it easier for you!
Good luck whatever you do!!!
8thumpers
#41
Quote from: "toyofan"Hi, cool project!!!
Thanks for the suggestion...
The issue is that the Audi shafts are HUGE compared to the Toyota ones - mixing bearings from the 2 marques just won't work....
The fabrication of the new hub is quite straightforward really! - keep the suggestions coming tho   s:) :) s:)
secla
#42
The norm on engine swaps is to make a half and half shaft with inner Audi and outer Toyota
Having to widen and rework hubs seems a bit more complicated
8thumpers
#43
Quote from: "secla"The norm on engine swaps is to make a half and half shaft with inner Audi and outer Toyota
I was keen to have upgraded shafts and hubs with all that torque  - hence keeping the Audi ones. [emoji4]
8thumpers
#44
This gives you an idea of the extra strength in the Audi shaft.
jonbill
#45
It's a bit thicker isn't it [emoji3]
8thumpers
#46
The 40 valve ABZ v8 4.2ltr
8thumpers
#47
Quote from: "jonbill"It's a bit thicker isn't it [emoji3]
Just a bit! Lol
8thumpers
#48
Rear bumper off and some crash damage discovered to rear bumper bar. I'll get something fabricated here anyway to suit Obiwan
8thumpers
#49
Zorst is off. If anyone wants a nearly new cat and sports manifold let me know....
The box isn't bad either.
