Tte turbo reference
Started by wotugonado, March 11, 2018, 14:21
Runs better on colder plugs for sure.
Had colder plugs on the SP and the V6 has I step colder and they're iridium's. Too much faff changing plugs on the V6 every year.
wotugonado
Tte  owners can I ask what mpg your getting please ?
@s12vea
@Ardent
s12vea
Not sure of mpg but full tank would usually get me 260 miles (my daily commute) but when drive hard I'm not sure.
TF204 Blue
Another one won't hurt  .....
wotugonado
@s12vea
Do you know roughly what the amount of litres your fill up is ?
Dan I know my SP wasn't exactly the same but it is similar.
Worst mpg was 27 best was 40 average was 32.2.
Most fuel I ever put in was 40 litres.
It's a 48L or 10.6 gallon tank.
wotugonado
Cheers @1979scotte
Well I've just gone on fuelly and it's early days but my mpg is worse than yours which surprised me.
Wondering if all tte turbo's are around this figure, when driven properly of course.
s12vea
38 litres roughly. Same old story if driven with minimal boost they will return 40mpg but when drive properly mid to low 20s
TF204 Blue
wotugonado
Quote from: s12vea on April 22, 2018, 21:31
Ah that's ok then, mid 20's it is then 8)
Quote from: wotugonado on April 22, 2018, 21:27
Cheers @1979scotte
When not gunning it the SP is maybe more fuel efficient?
Lower revs for the same power?
Mid to low 20s?
Are you sure?
My V6 averages 25. With a supercharger!
Fuelly says I never got less than 27mpg with a turbo.
wotugonado
@1979scotte
Well it's a weekend car so I'm all about the driving properly. I'm seriously impressed your getting that mpg on yours though
Can be anywhere between late 20s early 30s when playing.
Will expect mid 30s on the run to sywell
Cheers @1979scotte
Fuelly takes quite a few consistent entries to build a reliable pattern, I was getting 55-60mpg at first on my standard PFL. Showing 29 after the Dales drive yesterday, which is about right. Obviously doesn't help with your TTE comparisons but give it time and it'll start showing more accurate data, especially if you do partial fuel ups and don't tell it.
Quote from: Call the midlife! on April 22, 2018, 23:02
Cheers @1979scotte
My fuelly records are based on 14 fill ups and 3300 miles.
Obviously my average is kept up because I do a lot of motorway miles going away for weekends and the like.
SuperArt
One tank of fuel seems to last me all year.
I'm not proud of it but fuel economy is pretty good on this TTE Turbo albeit from lack of use.
Best regards,
Arthur
wotugonado
Quote from: SuperArt on April 26, 2018, 23:15
Whoa  :protest: need to drive it more that's criminal
Quote from: wotugonado on April 27, 2018, 00:10
What he  :protest: said.
Why invest in a car for it to just sit there? ::)
SuperArt
Im always short of either time, energy or money. Last year work was pretty much my whole life so I had neither time or energy. A few weeks ago I lost my job so I have time and energy but can't justify the expense. It's all good - I've managed to find something better so hope to get the car on the road a bit more this year. 🤔 Might even make DD.
Best regards,
Arthur
s12vea
You need to attend DD mate, make it happen
TF204 Blue
Smcknighty
Nice thread. SP turbo is near enough tte for me to join in isn't it?  With the iridium plugs how often are you changing them? Also what oil change durations are you doing?
wotugonado
If its all relevant then by all means post up  :)
Oil change I do per annum, i don't do many miles per year as it's a weekend car. I always use Fuchs oil and change just before my MOT.
I used to do sparks at the same time, but these iridium last longer so perhaps every couple of years now.
wotugonado
Tte exhaust clamps and metal gasket part numbers as found by  ManInDandism
1. KLARIUS EXHAUST GASKET
Klarius Part No: VOG5AP 410243 (listed for Volvo 240 and 740)
Euro Car Parts Part No: 700660050 (listed for Audi 80 as well as several Volvos including 240 and 740)
Euro Car Parts Price: £3.79
Dimensions: Height = 10mm, Inner Diameter = 51mm, Outer Diameter = 67mm
2. KLARIUS EXHAUST CLAMP
Klarius Part No: PGP55AE 430173 (listed for Peugeot 205 Berlingo)
Euro Car Parts Part No: 712745101 (listed for Citroen, Peugeot, Fiat, Nissan and others)
Euro Car Parts Price: 2.39
Dimensions: Diameter 69mm
Smcknighty
What happens when you feed these cars normal unleaded rather than the high octane stuff? Jo just filled the car up for me for the first time.
wotugonado
It'll run poorly, don't know if it will do damage, but if it were me id put a shot of octane booster in to get the Ron up
Stay below 3.5k rpm.
Hopefully the knock sensor will prevent it blowing up.
As Dan said get octane booster in there.
Is it a proper TTE or does it have SP mods?
