ZZZZZzzzzz electrical Noise from streering wheel
Started by Anonymous, February 22, 2006, 14:17
Hello,
when I'm stopped and the steering wheel is still (not moving/turning), I hear a small ZZZZZZZZZZZZZZz electrical noise.
When i steer a bit that noise stops. When I leave it still again, that starts again.
Any ideas?
Liz
Perfectly normal according to Toyota - mine did it for ages before the power steering pump went!
You should not be able to hear it from inside the car, though.
Quote from: "Beanie"You should not be able to hear it from inside the car, though.
I can. Been there for about 12 months now & noticeable when I park up. MrT assure me its nothing to worry about, and it goes away with the slightest twitch of the wheel.
philster_d
yep my mk 2 did it at startup untiil it got up to pressure, presumably the pump whining
Yeh mine did this too, unfortunately the only cure is to replace the pump/motor as I had to  s:( :( s:(
Another issue.
When I full steer the steering wheel left or right during parking, at the full lock, I hear something like squizing... is that normal ???
heres the inspection details for the vane pump
 m http://www.tandridgecanoe.co.uk/roadste ... ection.pdf m
