Oil advice and recommendations
Started by oilman, March 2, 2006, 12:11
oilman
I get asked many questions about oil so I thought a thread here for all oil related questions would be a good idea and build into a FAQ or reference point for others.
So, put your oil questions here but please give the following information if you would like a recommendation:
Make
Model
Year
Engine size/type
Any mods
Type of use (road/track)
Additional info (max oil temps, current oil used)
What do you want a recommendation for? Engine, Gearbox etc?
I hope this will help and become a useful thread
Regards
Simon
Use the code MR2OC and get 10% Club Discount
oilman\'s website: http://www.opieoils.co.uk/ - register for news and offers
email: sales@opieoils.co.ukphone: 01209 202944
Make  Toyota
Model MR2 Roadster
Year   2000
Engine size/type 1800 1ZZ FE
Any mods
Type of use (road/track) Fast road/occaisional track
No idea re oil temp but  water temp guage @ 1/2 way~90deg?
oilman
I would recommend 5w-40 synthetic, if you are doing trackdays make it a decent one though.
Simon
Quote from: "oilman"make it a decent one though.
Simon
Simon, I am not sure if I am alone, but whilst the rating (5W-40) is a fairly simple idea to get hold of, how do we rate manufacturers (Castrol, Mobil, Silkoleen, Motul, Halfords etc. etc.). I reckon most will do 5W-40 and some even have different products on the same rating.
How would we (or you) rate them, and on what basis. If you are not track daying, can you afford to put in the "non" decent one?
Thanks for your help. Roger
Make: Toyota
Model: MR2
Year: 2000
Engine size/type: 1800 /1ZZ-FE
Any mods: No
Type of use (road/track): Road use, driven hard when warm. Mileage approaching 50k
Additional info (max oil temps, current oil used) Currently using 5w 30 semi syn as per owners manual. Car is drinking up to 1 litre every 2k at the moment on this though..  s:( :( s:(  Toyota tell me this is within tolerance!!  s:roll: :roll: s:roll:    s:lol: :lol: s:lol:
What do you want a recommendation for? Engine, Gearbox etc? Engine please.
Roo
oilman
Quote from: "roger"
Simon
If you are seriously tracking the car then I would recommend that you look at these two race 5w-40's on our website.
Silkolene Pro S 5w-40
Motul 300V 5w-40
Street 5w-40's that I recommend are:
Fuchs Titan Supersyn SL 5w-40
Motul 8100 5w-40
Simon
oilman
Quote from: "Roo"Make: Toyota
Model: MR2
Year: 2000
Any mods: No
Roo
You would get better consumption from a 5w-40 synthetic, look at the street ones I have recommended above.
Simon
i just put in castrol gtx 10/40... is that ok for the car? if not i'll get it changed asap
Make: Toyota
Model: MRS
Year: 2000
Engine size/type: 1800 /1ZZ-FE ?
Any mods: No
Mileage: 21k
1ZZ Hass Turbo
260bhp-ish @ 10psi
30K miles
Simon, when I spoke to you at JAE you recommended I use Motul 5W-40 for my engine, which I happily bought and used. When I took my car to Thor, they recommended a thicker oil as the engine was noisy as hell when warm, so I'm now trying Mobil1 15W-50.
I've read your explanations on why you don't need as thick an oil as most people think before, and I'm not trying to start a Opie-vs-Thor debate here, but at the moment I'm tending to side with Thor on this one. My engine is far less rattley than before (expected, obviously), but I'm just curious on your thoughts on this. Is a rattley engine a bad one? Or am I sacrificing power unnecessarily?
Simon,
I've been working on the car today and noticed the oil was low so i've referred to the service manual and it has two recomendations, one is 0w-40 and 5w50 every 15000km, second is 5w40 every 7500km, which should i use, i only need to top it up?
oilman
Quote from: "RoadRunner"i just put in castrol gtx 10/40... is that ok for the car? if not i'll get it changed asap
Make: Toyota
Model: MRS
Year: 2000
Any mods: No
Mileage: 21k
The GTX 10w-40 is ok, adaquate.
If the car is driven hard I would look at a 5w-40 full synthetic as the quality option.
Simon.
oilman
Quote from: "Ekona"1ZZ Hass Turbo
260bhp-ish @ 10psi
30K miles
All the 15w-50 is doing is dapening down the noise, once an engine gets modded to an extreme they tend to be noisy, this is not a bad thing but if you are happier with the 15w-50 then stick with it.
Simon.
oilman
Quote from: "bossman23780"Simon,
5w-40 will be fine mate.
Simon.
 s:) :) s:)  cheers simon
Make Toyota(unless someone else makes the MR2 roadster!)
Model MR2 Roadster
Year 2003
Engine size/type 1798cc 1ZZ-FE
Any mods Engine wise, dual exhaust, Apexi power intake, Unichip, RPS Flywheel, RPS Clutch
Type of use (road/track) Yep, both
Additional info (max oil temps, current oil used) Mobil 1, Motul RBF600 brake fluid
philster_d
Read the label, Fully synthetic oil is best but most expensive. Semi synthetic doesnt necisarilarly mean half, just that it contains some synthetic oil and some non (even a low percentage is still called semi so buyer beware).
Phil
oilman
Quote from: "kanujunkie"Make Toyota(unless someone else makes the MR2 roadster!)
Model MR2 Roadster
Year 2003
Hi,
For your roadster we would suggest a 0w-40/5w-40 full synthetic, so the Mobil, assumin you are on 0w-40 is fine.
For the gearbox, a 75w-90 gear oil, again synthetic is best, have a look at Motul and Silkolene.
Simon.
Make: Toyota
Model: MR2 Roadster
Year: 2001 31K
Engine size/type: 1.8 vvti
Any mods: No
Type of use: Road
I want the car to runner a bit smoother with less engine noise and wear. I do drive hard and i'm burning about 500ml every 1500miles.
Many Thanks
   Ryan
Make Toyota
Model MR2 Roadster
Year 2003 23K miles
Any mods Unichip/H&S twin exhaust/TRD panel filter and H&S air intake (good chance I may be going for the TTE turbo install but have a service in four weeks so will be changing the oil then).
Type of use (road/track) Road
Additional info (max oil temps, current oil used) Rubbish Toyota drop in during service.
What do you want a recommendation for? Engine, Gearbox etc? Engine & gearbox.
oilman
Quote from: "extremeMR2"Make: Toyota
Model: MR2 Roadster
Year: 2001 31K
Any mods: No
Type of use: Road
Many Thanks
   Ryan
Use a decent street 5w-40 like Motul 8100 5w-40 or Fuchs Titan Supersyn SL 5w-40 and you will find the car a lot smoother.
Simon
jonytom
Make - Toyota
Model - MR2
Year - 2003
Engine size/type 1.8 1ZZ
Any mods - Markiii air inlet pipe and TRD air filter
Type of use - road (regularly gets a good half hour thrashing on country lanes)
Just got some Mobil Super-S 10w40 semi-synthetic. Semi-synthetic used up until now (from dealer). Any thoughts?
[size=75]Black \'03, black leather, TTE lowering springs, Markiii pipe, Corky\'s plate, J-Spec steering wheel badge, club windscreen sticker, red calipers with Toyota styling, Toyota GB body kit, Goodyear F1 Eagles (GS-D3), Dev\'s keyhole covers, black (painted) J-Spec nose badge[/size]
oilman
Quote from: "jonytom"Make - Toyota
Model - MR2
Year - 2003
Hi,
Yes the oil is fine, however semi synthetic is really the cost option, the quality route is for a 5w-40 full synthetic.
Simon.
Quote from: "heathstimpson"Make Toyota
Model MR2 Roadster
Year 2003 23K miles
You've forgotten me Oilman  s:wink: :wink: s:wink:
make toyota
model mr2 roadster
engine 1.81zz
year 2002
no mods.
general use with some "spirited" driving
oilman
Hi Guys,
Anyone need an oil recommendation?
