Things to do for my C2 turbo install - please help
Started by philster_d, March 15, 2006, 13:35
philster_d
Here is my to do list for Hungary and going C2 power.
I have alot to do and buy in only 2 weeks. Any tips, links or suppliers greatfuly accepted.
Philster
    MOT
    Fit Pre Radiator
    Engine Mounts - Kirks
    Wideband O2 sensor
    Charge cooler Pump    - Got one from Subaru legacy 2.5T
    charge cooler             - Got one from Subaru legacy 2.5T
    charge cooler radiator   - Got one from Subaru legacy 2.5T
    Navpod
    Chargcooler pipework enquire on IMOC - *done*
("Many use 3/4inch Plastic hosing found cheaply and easily in Aquarium / pond shops " Also use the 3/4" "L" connectors from the same shop for 90degree bends - to prevent "kinking" - all nicely tightened up with jubilee clips)
Insurance
    Check for new mods cover  - Done now insured at £1008 includes coilovers (added £150 to my remaining 5 or so months *still half my last modded tubby insurance*)
    Cover for drive to hugary  -  Done Green card on its way to me along with the insurance changes
    Extend limited mileage  -  Done to unlimited
ferry booking and times
European car rules and reqs
Markiii's list
    Locking K-nuts (high temp) Demon Tweeks (ask gas for sizes)
    USB Cable for e-manage
    E-manage pressure extention harness
    E-manage ignition harness
    E-manage accessories harness - for wideband o2 sensor
    CAT 5 cable to extend profec display from control box location
Gaspar items
    C2 kit
    E-manage
    Profec
    Clutch
Spending money
Follow up activities......  ? ?  ?  ?
    replace nuts with  ? ? ? ? ?  (cant remember the name? Nylock or something?)
And............
replace nuts with nylocks
emanage harness is
 m http://www.boomslang.us/shop.htm m
should mean you don't have to buy teh ignition harness if you go for teh right one.
stil missed off teh european breakdown cover
 and leave passenger seat out so you can everything back
Quote from: "markiii"replace nuts with nylocks
nylocks on the exhaust bits would seem like a bad idea to me - the nylon will probably melt..
Oval nuts would be a good one, though (single use, they deform to grip the stud by becoming round), or use the old trick - one thick copper nut followed by a thin half-thickness copper nut wound on to the back of the first.
i really wouldn't fit the chargecooler Phil, this could create more problems than its worth for Gas, i'll fit the rad for you but do the guy a favour and dont fit it.
Quote from: "aaronjb"
eekk didn't mean exhaust I meant intercooler brackets and that kind of thing
Quote from: "markiii"eekk didn't mean exhaust I meant intercooler brackets and that kind of thing
Ahh ok.. I'll shut up now  s:) :) s:)
You: Passport, Driving License, Logbook, Holiday insurance, Camera & phrase book, card PIN numbers, GBP cash (you never know what it'll buy you!), Map/GPS European Maps, Wig and medallion  s:wink: :wink: s:wink:
Car (optional): Cable ties, Gaffer tape and basic tools - just in case. Euro breakdown cover - again, just in case (and you generally have to notify them in advance that you're going).
re. IGN harness - Gas doesn't map IGN as standard, but I'm guessing you've arranged to have this done?
Worth making sure you have the latest firmware upgrade for wideband too, but this is available online.
Follow-up activities: bring back Ste's sandwich plate and haggle for a MAF-TB pipe for me?
Quote from: "spit"Car (optional): Cable ties, Gaffer tape and basic tools - just in case.
9 mm to 12 mm box wrenches and a couple of screw drivers should do it. Gloves as well if you end up having to work on any hot bits.
I'd also go with a smaller hex ratchet socket to tighten the jubilee clips if necessary (6mm I think, or is it 8?) - so much easier on your knuckles than using a screwdriver  s:oops: :oops: s:oops:
philster_d
Work on hot bits - ?
I honestly wouldnt have a clue, thats a risk I guess
Phil, definately get yourself a pair of welder's mitts: They're pretty much heat-resistant, and if a bolt or clamp comes loose on the way back, you'll definately need them on to work anywhere near a hot turbo/exhaust.
Trust me on this, I had to do some emergency repairs about 30mins after leaving Mark's house the first time after my install. They're only about a fiver anyway, and will be worth their weight in gold should you need them.
philster_d
Whats in the european car rules ? triangle, first aid kit etc?
Also who said they can lend me the stuff? was it you stu ?
Ill call the aa tomorow i am a member already.
twas me, I have bulbs, and warning triangle and tow rope
you will need to get a fire extinguisher
you may also want o see the new driving abroad thread above us.
philster_d
Germany > none unless shown
yay
Germany
On unrestricted sections of autobahn if your travelling at over 120Kmh iand have an accident it's assumed to be your fault, period.
Bongo
What if both parties are doing > 120?
philster_d
Code reader - For european car  - Anyone got a link to the correct thing ?
I dont even know what they look like.
Yes spare seat out, where do I get the wideband 02 thing (and what ?)
Philster.
philster_d
To buy list
Item.................................Suggested supplier
Navpod.............................Japan Parts
Engine Mounts...................
Wideband O2 sensor..........
Pipework + Corners........... B&Q or Aquarium shop
Jubilie Clips.......................
Ferry Tickets or Eurostar....
Fire extinguisher...............
Dark blanket to cover things up in the car............
Locking K-nuts.................. Demon Tweeks
E-manage accessories harness - for wideband o2 sensor ------- see below ? ? ?
Plug and play for e-manage............ m http://www.boomslang.us/shop.htm m
...............includes Main, injector and ignition............How many of the above does this cover ? ? ?
Phil,
that harness simply means you don't need teh ignition harness, you will still need the others.
ref teh Knuts you need to order them this week, if you gettiung them in time
ref code reader you can borrow my pocketlogger if that helps.
philster_d
I still want one anyway
I asked gas the bolt sizes but he hasnt replied yet.
i need to confirm with him im comming and book the ferry etc...
Phil
Phil i still have my wideband O2 that i used with my PE setup if your interested. Here for details it's the m-300  m http://www.plxdevices.com/M-Series_productinfo.htm m
Quote from: "philster_d"Code reader - For european car  - Anyone got a link to the correct thing ?
Here's what I have:
 m http://cgi.ebay.com/OBD-2-CHECK-ENGINE- ... dZViewItem m
IIRC, Slacey had the same and it's quite popular on the other side of the pond..
philster_d
Thanks Tem.
Now I told my GF she is realy upset.  She is begging me not to go, even if I have to pay more to get it delivered etc. Also shes worried me driving that far alone.
  s:? :? s:?
Why not go together and make a holiday of it?
