Things to do for my C2 turbo install - please help
Started by philster_d, March 15, 2006, 13:35
I really wish I could make it to go with you mate  s:-( :-( s:-(
philster_d
any more suggestions for suppliers ?
Item.................................Suggested supplier
Navpod.............................Japan Parts
Engine Mounts...................
Wideband O2 sensor..........
Pipework + Corners........... B&Q or Aquarium shop
Jubilie Clips.......................
Ferry Tickets or Eurostar....
Fire extinguisher...............
Dark blanket to cover things up in the car............
Locking K-nuts.................. Demon Tweeks
USB Cable for e-manage
E-manage pressure extention harness
E-manage accessories harness - for wideband o2 sensor
Ebay for these harnesses  ? ? ? ?
Will that, offered above, wideband o2 thingy work for me ?
Thanks for the answers tomorow will be order everything day (I hope)
Phil
Engine mounts Kirkosauras (SC)
emanage cables  w www.mohdparts.com w
that wideband o2 should be fine
philster_d
OK so heres the list of parts to get so far and ...... a supplier
Engine Mounts...................Kirkosauras (SC)
Wideband O2 sensor.......... mrs-turbo ?
USB Cable for e-manage................www.mohdparts.com
E-manage pressure extention harness..........www.mohdparts.com
E-manage accessories harness - for wideband o2 sensor...........www.mohdparts.com
Still hoping to get on the ordering trail tomorow
Didnt hear from Gas for a day or too... ooops    s:? :? s:?   well im acting as if all systems go.
Philster.
Quote from: "philster_d"Didnt hear from Gas for a day or too... ooops    s:? :? s:?   well I'm acting as if all systems go.
Philster.
Don't panic Phil, I spoke with Gas last night and he is expecting you - he is just ridiculously busy at the mo making bespoke parts for fussy C2 customers  s:wink: :wink: s:wink:
philster_d
I need those bolt sizes or ill miss the boat so to speak   s:lol: :lol: s:lol:
Quote from: "markiii"emanage harness is
 m http://www.boomslang.us/shop.htm m
should mean you don't have to buy the ignition harness if you go for the right one.
Got mine today, awesome piece of wiring-goodness. Not tried it yet, but it looks sexeh enough.  s8) 8) s8)
Let me know if you want it, Phil.
Quote from: "philster_d"Engine Mounts...................Kirkosauras (SC)
Philster.
Folks have been using the 3M window weld for the motor mounts as well. There is a write up on Spyderchat somewhere...
Quote from: "barkingspyder"
Philster.
Phil knicked my unfitted kirks mounts today and is going to replace them when he gets his delivered, fingers crossed, no window weld  s:? :? s:?
TommyD
Phil,
If you want a OBD reader, I can recommend a Car-Pal from Vital Engineering.
http://www.car-pal.net
You can use it with a PC, Pocket PC or Mobile phone with blue tooth. With the laptop software you can even record 0-60 times   s:D :D s:D
[size=100]Sable MR2[/size], David\'s Bars, TTE Rear Sports Spoiler, TRD side skirts, TRD front cross brace, Lampka rear cross brace and under bracing, Whiteline swaybars, Whiteline spings, 2\'srus Drop links, RPS clutch
LeeUK
#36
Quote from: "spit"- he is just ridiculously busy at the mo making bespoke parts for fussy C2 customers  s:wink: :wink: s:wink:
Would that be me?   s:oops: :oops: s:oops:
[size=100]JELBE[/size]
[/color]
The bolts are M8. My english is not good enought to unserstand what you want to do with them, but I am sure we can lock them for you not to get loose.
LeeUK
Gas, let me know the best way to keep these bolts locked on, as Markiii who has the Hass kit had his bolts drop out and he ended melting half his engine bay.
Lee
[/color]
Gas just to be clear the studs I had a problem with sheared, and were manifold to turbo
What we use now is the cast iron manifolds with studs and not bolts and locking mothers. Does it help?
I am suggesting a drilled small hole and some "cable??" thru in it like on race applications. Easier and faster solution to point weld them after install.
Quote from: "LeeUK"Gas, let me know the best way to keep these bolts locked on, as Markiii who has the Hass kit had his bolts drop out and he ended melting half his engine bay.
Lee
Loosing the turbo bolts would couse less air and run rich in mi view.
#42
Quote from: "LeeUK"
No I think you're sorted Lee - Gas is fixing me up a sandwich plate.
Phil, Gas's cast manifold arrangement sounds like you should be OK. I need to get me one of these - although a little realignment of my DP will be required, and maybe an adjustment of the turbo brace. But after seeing how welds can crack I think this will be a good investment.
#43
Has anyone got any pics of the cast manifolds (Gas?)? Very interested to see one  s:) :) s:)  (sorry Phil, slight drift!)
LeeUK
#44
I'll second that, my box of goodies should arrive soon but I'm too impatient!   s:roll: :roll: s:roll:  Pics pics pics!   s:D :D s:D
[/color]
My cam was stolen 2 weeks ago. I managed to get one today. Making pics sirs  s:) :) s:)
#46
Quote from: "c2gas"My cam was stolen 2 weeks ago. I managed to get one today. Making pics sirs  s:) :) s:)
Excellent  s:) :) s:)  Thanks Gas!
Now I'll let you all get back to talking about Phil's imminent arrival  s:) :) s:)
philster_d
#47
I wish I had a time lapse camera, then I could make a wicked movie of the journey across europe.
 s:( :( s:(
edward.carter
#48
Quote from: "philster_d"I wish I had a time lapse camera, then I could make a wicked movie of the journey across europe.
 s:( :( s:(
could stop every mile or so and take a photo lol and then when you got back stitch them all together   s:lol: :lol: s:lol:
philster_d
#49
I saw one that was a drive accross america it was so cool.
