New Engine Car not starting!! Help please!!!
Started by leon_in_uk, March 24, 2006, 15:39
SteveJ
Quote from: "leon_in_uk"these are the codes it first read before dimwit erased them..
P0100 Mass or Volume Air flow Circuit Malfunction
P0110 Intake Air Temperature Circuit Malfunction
others were
1300
1305
1310
1315
and cant seem to find them on that list you supplied..
so maybe the bloke on tuesday will be able to tell me which leads to get etc.
there are alot of codes though arent there?  s:( :( s:(
P1300, P1305, P1310 & P1315 relate to igniter failures on circuit 1,2,3 & 4 respectively.
I suspect all of the codes listed above are related to the wiring loom not being plugged in when the garage tried to start the engine for the first time.
As to the problem you are seing at the moment, I would be suspicious of electrical noise causing it - double check that all of the earth points have been reconnected and that the battery voltage is OK (in particular whilst the car is running).
If the light comes on, but then goes out (assuming you are not switching the ignition off in between) then it is unlikely to be the ECU that is intentionally switching it on.
leon_in_uk
oh the 13's would relate to the original post.. when he couldnt start the engine..
and i need to check the air flow wire/sensor..
but correct me if im wrong i am still going to get my car mapped and tuned properly, would you recommend this or will it be a waste of money, if i can sort this problem myself?
Previous:
BMW z4 3.0
Seat leon cupra mk2
SOLD:
bmw z4 2.0 sport
its probably worth while getting it checked over and tuned as its a new install. Never hurts to have a second opinion on the install
philster_d
Good luck Leon
leon_in_uk
thought so, its going in then stu..
but to sort the 0100 and 0110, which wire is that so i can double check at lunch time?
ta
Previous:
BMW z4 3.0
Seat leon cupra mk2
SOLD:
bmw z4 2.0 sport
its the mass airflow sensor you need to check, just unplug and check the connector on it. But to be honest i think Seve could be right, check the earths
leon_in_uk
ok will do,
anyone got a map or pic where this connector is? i will put some carb cleaner on it at lunch??
Previous:
BMW z4 3.0
Seat leon cupra mk2
SOLD:
bmw z4 2.0 sport
dont put that in the connector, but if your going to remove the maf and clean the senso as a whole then its the black square blob with a connector entering from ones side that lives in the pipe that goes between the airbox and the throttle body
leon_in_uk
thanks. will update on tue
Previous:
BMW z4 3.0
Seat leon cupra mk2
SOLD:
bmw z4 2.0 sport
leon_in_uk
i cant seem to do any good on here askinga general question re the ECU..
but had it checked today, everything is fine, but the problem still occurs..
The problem is!!! when revving my car upto 5.5k my engine tells my ECU not to do no more!!
so its defo the ECU not wanting more..
how much do you think i should pay for an ECU that corresponds properly?
thanks peeps
Previous:
BMW z4 3.0
Seat leon cupra mk2
SOLD:
bmw z4 2.0 sport
just as a point Leon, you have had it check by Mr.T?
it could still be the ECU restricting power because of a problem, get the OBD-II read to make sure
leon_in_uk
#36
not been checked by toyota. but a tuning and mapping specialist.
it is defo the ECU the tuning bloke said.. and it cant be read by one of them things becasue its not reading any propblems. and the light is not staying on!!
i have rung up the bloke selling the engine and he said i can have the ECU that came with it for £100 is that the right move? then gettting it mapped and tuned yet again??
thanks
Previous:
BMW z4 3.0
Seat leon cupra mk2
SOLD:
bmw z4 2.0 sport
Got to Mr T - they should be able to tell you for sure.  Dont know the guy - but I myself have been a bit miffed off with some people in the past with previous cars - who were supposedly 'specialists' the ones who are good, are always busy, and recommended highly.
Go to your local Mr T - and see what they say with the fault finding.
leon_in_uk
how much will they charge though?
Previous:
BMW z4 3.0
Seat leon cupra mk2
SOLD:
bmw z4 2.0 sport
Bongo
I didn't think you could map/tune a stock ecu?
I dont know, give them a ring and find out - its your car, so you know, you should really get a couple of opinions in sorting it out.
#41
Quote from: "Bongo"I didn't think you could map/tune a stock ecu?
you cant, thats the whole reason why the TTET uses a piggy back unit, TMC wouldn't release the programming code for the ECU, are you sure your tuner didn't attempt something and damage the ECU Leon
leon_in_uk
#42
no the car revs smoother.. and the problem occurs the same as it did before it was tuned today..
just after the 5.5k mark on every gear..
its basically a small jolt and no more revs, and a quick flash with the CEL light..
dont think its a major problem but he says all leads and wires etc are properly working the engine is in good working order, just the ecu not wanting to rev over 5.5k...
Previous:
BMW z4 3.0
Seat leon cupra mk2
SOLD:
bmw z4 2.0 sport
If Toyota charge you £50 for the diagnosis, it's worth it. Even if that cost doubles before you even get a chance to fix it at least you'll know what the problem is, and that's half the battle won.
leon_in_uk
#44
thanks. will get it booked in on sat. before villa loose again..
Previous:
BMW z4 3.0
Seat leon cupra mk2
SOLD:
bmw z4 2.0 sport
dimwit
#45
Do he say anything about a blocked injector? could cause the missing when asking for more fuel?..  s:? :? s:?
you can't and how the hell he knows that teh ecu is telling teh engine "no more" is beyond me
Quote from: "leon_in_uk"no the car revs smoother.. and the problem occurs the same as it did before it was tuned today..
define tuned? the stock ecu can't be tuned?
leon_in_uk
#48
said mapping and tuning to me.. to get the best out the revs..
and it wastnt anything else apart from the ECU. so not sure what he has done!!
Previous:
BMW z4 3.0
Seat leon cupra mk2
SOLD:
bmw z4 2.0 sport
edward.carter
#49
looks like he has took your money... told you he has tuned it..... and run...   s:? :? s:?    I would give him a ring and ask for a specific breakdown of exactly what has been done.
