Fitted my short shift!
Started by Anonymous, March 30, 2006, 10:05
A little two scared to take a dip without knowing more but a che shortstick and some speed source parts sound good but until today I didn't know how any of it worked?
edward.carter
Quote from: "kj"Thanks edward,
Just wondering has anybody done a write up on how to install the bushes on the cable?
Seen the report on installing the B+M stick and the metal brushes but whereabouts is the cable, sorry but my knowledge of gearboxs and such like is non existant  s:oops: :oops: s:oops:
the cable goes from the gearstick down the centre tunnel and into the engine bay and the speed source bushes replace the standard rubber ones on the end where the cable meets the gearbox (just behind the airbox) see here http://www.speed-source.net/shifter_cable_toyota_instructions.htm
edit: the only tricky bit with the cable bushes is getting the old rubber ones out because they are really stiff, but a good flat headed screw driver and and good push from your thumb and they do pop out eventually!   s:) :) s:)    the new ones just drop in in a matter of seconds
thats it exactly, once you have access to them, (may involve removing teh airbox if you still have it) it's a 10 minute job with needle nose pliers and a screwdriver
this has to be the easiest mod I'v ever done
Ok talked me into it, Should I buy the speed source metal brushes or are the pieces from che's kit ok
You dont get the speed source brushes with che's kit... you don't get any kind of brush. Che's kist comes with just the gear lever parts. You'll need to by the speed source bushes as well if you want to change the brushes.
edward.carter
two different things, the che short shifter kit bushes are the ones that go under the shifter cage under the actual gearstick.
the speedsource bushes go on the end of the cable in the engine bay
Arn't  these brushes shown in Che's kit.
Ernie Ball
Nope.  Those are the ones for under the shifter itself.
Ok
I'm now offically confused, the brushes in Che's kit only support the shortshifter to what for wont of another word is the deck, Yes? So do the speed source pieces connect to the cable or where, Am I being thick and will this all explain itself when I get the console off andf can see for myself. I,ve looked on the on line instructions but dont know what it is the pic are showing me
ok, back to basics
che's shifter bolts into a white plastic cage in which normally the oem non short shift stick sits
this white cage is supported from teh floor by 4 rubber bushes 1 at each corner
in order to enhance teh shift action and keep the pivot point teh same, che (and B&M if you buy theirs) supply 4 thicker metal bushings that you use instead to support teh 4 corners of the cage.
at teh other end of the gear cables (engine bay side) the cables terminate in an o shaped metal ring. this slips over pins on the actual gearbox shifter mechanism.
from teh factory the o ends of teh cables are lined with rubber bushings, the speedsource bushings are brass and replace these in order to further tighten and enhance the shift action.
that help?
Quote from: "kj"the brushes in Che's kit only support the shortshifter to what for wont of another word is the deck, Yes?
Yes.
QuoteSo do the speed source pieces connect to the cable
Yes.
 s;) ;) s;)
this article
 m http://www.mr2roc.org/subdreamer/index. ... ticleid=11 m
is for installing teh B&M shifter but since ches is to all intents and purposes a copy of teh B&M you it applies just as well and should illustrate the che's part of teh process
Thanks Guys,
50% for the answers 50% for having the patience to listen to the questions
I fitted mine today well yesterday and finished it today as it started to rain yesterday. Not a hard job but fiddly. make a big difference to how quick you can change gear and how direct it feels. I would recomed it to everyone
ninjinski
I know this has been discussed before just want to check - Isnt it true that the TRD short shifter is problematic with the 6-speed box? Otherwise I want one as not too keen on the off centre solution.
Just want clarification ta!
Sable
mg
#40
Quote from: "ninjinski"Otherwise I want one as not too keen on the off centre solution.
I thought the offset would be a problem as well, but after 6 months of the B&M, it's really is not an issue.  You just get used to it.  I still get a grin watching the wife with her 2 handed reverse selection though!  s:twisted: :twisted: s:twisted:
[size=67]2005 Silver | Red Heated Leather | TTE Turbo | TTE exhaust | TTE Lowered Springs | TRD FSB | B&M Short Shift | David\'s Style Bars | Bama Tall Deflector | Red Calipers[/size]
#41
Quote from: "karlus972"just fyi...
i installed the TRD shortshifter back in July last year (i think), and it was just easy......plug and play.   s:D :D s:D
The shift is stiffer and more direct.....lovely.
I especially didn't want to install the gimmicky shift sticks one can find on ebay, for the hassle of the install.
If it works fine for your slurpy that's great!   s:wink: :wink: s:wink:
How much did the TRD one set you back Karlus  s:?: :?: s:?:
karlus972
#42
Quote from: "heathstimpson"
I bought it from a guy on Spyderchat for 100 $ if I recall correctly. It's delivered with the white plastic "frame" and the knob   s:oops: :oops: s:oops:  . You just need to take the stock frame off, and screw the new one in. The only little pain we had was to fix a tiny little piece of metal underneath the stick, but it's just a matter of patience. I am very happy with it, it's to me one of the best mods I've ever done   s:wink: :wink: s:wink:
Madinina Style!!
edward.carter
#43
Quote from: "ninjinski"I know this has been discussed before just want to check - Isnt it true that the TRD short shifter is problematic with the 6-speed box? Otherwise I want one as not too keen on the off centre solution.
after a couple of weeks you honestley dont even think about it being off centre, you do get used to it  s:) :) s:)
TRD do actually list a seperate kit for a 6 speed box, see here
 m http://trdparts.jp/english/list_mr-s.html m
but I've never found anyone who supplies it outside of Japan, just 5 speeds only.
#45
Quote from: "mg"I still get a grin watching the wife with her 2 handed reverse selection though!  s:twisted: :twisted: s:twisted:
I grin even more...now she's stopped driving it   s:D :D s:D
Your right this dosn't look to hard, Had a look today and I can see what needs changing, So I think I'll treat myself to a early birthday present with a Shortshifter from Che and a Shifter Cable Bushing Kit from Speed Source, they also do a Shifter Base Bushing Kit
I don't need these though Right?
Just wondering has anyone ever bought any of the gear knobs from them? They look a nice piece of kit but I'd probabley be able to get something similar from this end of the Pond.
edward.carter
#47
nope you dont need the base bushes as these are included in with the che  s;) ;) s;)
#48
only difference between Che's short shifter mounts and those, is Che's are alluminium and those are brass
edward.carter
#49
Quote from: "kanujunkie"only difference between Che's short shifter mounts and those, is Che's are alluminium and those are brass
Think of the weight saving   s:lol: :lol: s:lol:
