Front Wheels and Power Steering
Started by leon_in_uk, May 10, 2006, 09:02
leon_in_uk
hi, guys i have had my car back.
since the garage have had my car, the steering is heavy and seems like the power steering kicks in sometimes when turning the corners..
i checked the pressure and left is 34 and right is 35.. is that about right?
also what could this be? they did toe is from the front wheels, have they knocked around with the alignment.?
Previous:
BMW z4 3.0
Seat leon cupra mk2
SOLD:
bmw z4 2.0 sport
GSB
First of all, read your manual, or at least look at the sticker inside the glovebox, and learn something about your car that could very well save your life. Your front tyre pressures are far to high....
Sort your pressures out, and then see how it feels.
leon_in_uk
well if i lower the pressures, then the steering would be even more heavier wouldnt it? must not be the pressures then.. must need aligning.
Previous:
BMW z4 3.0
Seat leon cupra mk2
SOLD:
bmw z4 2.0 sport
GSB
Quote from: "leon_in_uk"must not be the pressures then.. must need aligning.
  s:roll: :roll: s:roll:
Check. The. Pressures...
How do you expect he car to handle or feel right when the front tyres are 30% over-pressure?
leon_in_uk
oops just checked its meant to be 26....
i will sort that out later, but i think it might be the alignment still
Previous:
BMW z4 3.0
Seat leon cupra mk2
SOLD:
bmw z4 2.0 sport
edward.carter
or power steering pump failure?
Liz
Quote from: "leon_in_uk"oops just checked its meant to be 26....
You have had your car how long and you only just seen what the pressures should be   s:shock: :shock: s:shock:  .... if your power steering pump has gone you are looking at around £200 inc labour to get it fixed if you get a second hand one...£1K for a new one from Mr T
GSB
Quote from: "edward.carter"or power steering pump failure?
Could be.... But, when fault findng on any system, always investigate the statistically most likely and dazzlingly obvious possible causes first. Only then do you investigate further
Put it this way, if the engine wont start, do you first;
a) Replace the engine, or
b) check you havent run out of petrol?
leon_in_uk
jesus.. more money..........
its only been like this since the bloke who sold me the engine has had my car. im gonna get him to have a look at it!!
Previous:
BMW z4 3.0
Seat leon cupra mk2
SOLD:
bmw z4 2.0 sport
leon_in_uk
it cant be power steering pump, i have tried turning the steering wheel when the car is stationary and the wheels turn fine. as if the pump is working...
just when driving, and turning the wheel slightly seems like for a bit its light then heavy and light and heavy...
like the wheels are flat...
Previous:
BMW z4 3.0
Seat leon cupra mk2
SOLD:
bmw z4 2.0 sport
well as grant says first check the obvious
if tyre pressure don't fix it, perhaps there is a loose connection on the wiring for teh PS pump, and this is why it could be intermittently on.
you definately need a plan of action to elimate step by step
the scatter gun approach will just confuse the issue
SimonC_Here
Quote from: "leon_in_uk"...
Sounds just like my recent problem. See my post about 'Square' stearing when cold.
Do the tire pressures first though. Costs nothing and if it doesn't work at least your tires will be at the right pressures!
Simon
leon_in_uk
tyre pressures are now fine. and the problem is the same, i dont even think the power steering is on. so must be the steering system!!
since the car was on a toe truck with the front wheels were lifted off the floor, i think that might be the problem..
Previous:
BMW z4 3.0
Seat leon cupra mk2
SOLD:
bmw z4 2.0 sport
why?
leon_in_uk
maybe he has knocked the PS wires, or knocked something out of place.
it was fine the last time i had my car...
Previous:
BMW z4 3.0
Seat leon cupra mk2
SOLD:
bmw z4 2.0 sport
edward.carter
from simons thread: Have you check the level of the power steering fluid? could be either its low or you've got an air bubble in the system?
 m http://mr2roc.org/phpBB2/viewtopic.php? ... ering+cold m
Liz
Asking the glaringly obvious here - does the Power Steering light come on on the dash?
leon_in_uk
nope
Previous:
BMW z4 3.0
Seat leon cupra mk2
SOLD:
bmw z4 2.0 sport
Now that you've confirmed your tyre pressures, I would go check out your power steering fluid (See simon_c's post) and I would also check the fuse for the power steering.
Richie
leon_in_uk
fluid checked and that is fine, and no air came out either..
the PS is on when the car is stationary. so wont be the fuse...
just heavy when driving.
Previous:
BMW z4 3.0
Seat leon cupra mk2
SOLD:
bmw z4 2.0 sport
SimonC_Here
After a storming result on the springs you bought  s:P :P s:P , remember to get them fitted before you get the wheels aligned.
You don't want to have to do it twice!
Simon
leon_in_uk
will do.. im gonna get the alignment looked at when the engine is fitted, to see what the salvage bloke has done.
the idiot..
Previous:
BMW z4 3.0
Seat leon cupra mk2
SOLD:
bmw z4 2.0 sport
Ahh the irony..
Quote from: "Slurpy J"Ahh the irony..
s:lol: :lol: s:lol:
leon_in_uk
this is strange...
last night for a ten minute drive and this morning for a 5 minute drive the turning and power steering was fine...
just like normal steering..
i dont understand.. could be that the battery was flat a couple of days ago, and did a big journey yesterday could it? (the alternator recharging the battery)
i dunno. but strange
Previous:
BMW z4 3.0
Seat leon cupra mk2
SOLD:
bmw z4 2.0 sport
