Clutch/transmission issue
Started by Tem, May 12, 2006, 10:05
rmowbray
Debris between plate and flywheel causing draging???
Which has now either worn away or dropped clear???
Update...seems the real issue was the clutch main cylinder seals. After I replaced them, the issue seems to have gone for good.
Before that I replaced the slave sylinder seals, assuming they might've disliked the extra heat from the turbo, but the issue came back after a while. It was always working for some time after bleeding, but eventually failed. Now it has been fine for two tanks of gas.  s8) 8) s8)
Oh and when someone else needs to bleed their clutch, I found the easiest way was to remove the small cover on the clutch reservoir cap (there's a hole under it) and use a small compressor meant for filling up tyres to pressure bleed it. Also had Speedbleeder instead of the normal nipple, which make it a lot easier.
