TRD Quickshifter - leather cover?
Started by Sam, October 3, 2003, 10:22
Sam
Hi all,
Installed the TRD quickshifter last weekend - just wondering anyone else installed it? What did you do about the leather cover for the stick - as on the standard stick the gearknob screws on and holds it up, whereas with the TRD knob it hangs loose...
Or have I just missed something here   s:roll: :roll: s:roll:  ??
Cheers,
Sam
[size=75]\'01 Black Roadster
Leda Adjustable Struts/Eibach Springs/TTE Stabilizer Bars/TRD Bracing/TTE 17" 9-Spokes/Toda Flywheel/Unichip/TTE Exhaust/TTE Front Bumper/TRD Quickshift[/size]
Quote from: "Sam"Hi all,
Cheers,
I assume you are talking about the leather shifter boot? I have the B&M, and there is a little (kind of oval) bit of plastic on the stock shifter that clips onto the shaft and holds the boot up - this was re-used on the B&M stick, so no problems... I would assume the TRD will re-use that same bit, check the instructions again carefully, might be that you missed it.
Oh, and before eveyone else say's it.... "he said 'shaft', hu hu hu!"
Sam
Slacey, I know the bit you are talking about - so basically you end up with the leather covering most of the stick, then a gap of exposed stick then the gearknob?
Dont you find the metal ring attached to the leather boot rattles around against the stick?
Sam
Quote from: "Sam"Slacey, I know the bit you are talking about - so basically you end up with the leather covering most of the stick, then a gap of exposed stick then the gearknob?
I suppose it depends on the knob (fnarr), my B&M meets up nicely with the chrome ring... see below.
Sam
Cwor, photo already - you're a bit efficent! Maybe I need a new knob   s:lol: :lol: s:lol:
PS. Nice to see another Black/Red Leather Roadster - the only colour scheme worth considering   s8) 8) s8)
Sam
Quote from: "Sam"Cwor, photo already - you're a bit efficent! Maybe I need a new knob   s:lol: :lol: s:lol:
If you look at some other threads, you will find scientific evidence that the Silver/Red combination is the best one can have.
Darth Paul
Quote from: "Slacey"
F'narr, he said 'ring'.
DP
Not quite, that pic was taken last year and has been uploaded before, so one of my 'stock' pics!
