Handbrake failure
Started by kanujunkie, June 6, 2006, 09:45
we went to a friends place last night and whilst i was stood there looking out the window what do i see but the car slowly rolling past but the 2!!!!!
looks like the handbrakes failed  s:( :( s:(  , Mr.T's going to look at it tomorrow but it aint good, fortunatley it only clipped a curb and not anything else
ninjinski
whew mate that was lucky nothing worse happened!!!   s:oops: :oops: s:oops:
Sable
could so easily have been worse, Mr.T tried to say that theres small brake shoes in the calipers that must have worn, new one on me i thought there was the main pads and thats it, me thinks theres some bull going on here  s:? :? s:?
Quote from: "kanujunkie"Mr.T tried to say that theres small brake shoes in the calipers that must have worn, new one on me i thought there was the main pads and thats it, me thinks theres some bull going on here  s:? :? s:?
Local T said the same to me!
It's the main pads through a wire in real life though. But if they want to replace small brake shoes, please let them do so. Don't forget to ask for their part numbers for future though!  s:lol: :lol: s:lol:
(don't you leave your car in gear?)
My drive is on a slope and I dread that one day its going to roll away. I worry that if I leave it in gear I will forgot @ 5 in the morning and crunch the balcony pillar 2" in front of where I park  s:? :? s:?
Quote from: "kanujunkie"could so easily have been worse, Mr.T tried to say that theres small brake shoes in the calipers that must have worn, new one on me i thought there was the main pads and thats it, me thinks theres some bull going on here  s:? :? s:?
Yep, some definite bull going on there..
Quote from: "heathstimpson"My drive is on a slope and I dread that one day its going to roll away. I worry that if I leave it in gear I will forgot @ 5 in the morning and crunch the balcony pillar 2" in front of where I park  s:? :? s:?
same here i know ill end up in my garage door if i leave it in gear   s:? :? s:?
Quote from: "heathstimpson"I worry that if I leave it in gear I will forgot @ 5 in the morning and crunch the balcony pillar 2" in front of where I park  s:? :? s:?
Ah, the beauty of SMT!  It won't start unless it's in neutral and your foot on the brake pedal.
hmmm, wonder if i could wire the same thing up on mine  s:? :? s:?
Quote from: "nic_wigan"
You should notice it the moment you turn the key and it probably won't even start.  s8) 8) s8)
I have a habit of flooring the clutch and brake pedals and making sure the stick is in neutral before I start. Just in case. I have tried to drive off with the handbrake engaged several times though, cause I only use it on very steep hills, like once a year or so.  s:lol: :lol: s:lol:
i think i check  the handbrake is in neutral about 500 times before i start up and i know ive checked it and i still have to check again   s:shock: :shock: s:shock:
Quote from: "nic_wigan"check  the handbrake is in neutral
Ermmmmmm...  s;) ;) s;)
Liz
You got a balcony!!
Quote from: "Tem"
I generally always start up with the clutch depressed as its good practise and check its in neutral,  but when half asleep leaving for a dayshift I worry that just maybe one day I will forget  s:? :? s:?
Quote from: "Liz"
You got a balcony!!
Oh yes its cheaper up north that's why I left London  s:wink: :wink: s:wink:  My bedroom sits above the double garage which has french doors leading to a full length balcony with nice views. Should have moved up my way and saved yourself a fortune Liz  s:wink: :wink: s:wink:
problem is i need more feet, normally i would have pressed the clutch and brake then turn the key, but now with the turbo fitted i need to press the clutch, brake and accelerator before i turn the key  s:? :? s:?
Quote from: "heathstimpson"My bedroom sits above the double garage which has french doors leading to a full length balcony with nice views.
....until the MK Development Corporation add a few thousand more houses   s:wink: :wink: s:wink:
jonytom
Quote from: "heathstimpson"up north
Milton Keynes! Cor blimey govn'r, you're havin a larf!
[size=75]Black \'03, black leather, TTE lowering springs, Markiii pipe, Corky\'s plate, J-Spec steering wheel badge, club windscreen sticker, red calipers with Toyota styling, Toyota GB body kit, Goodyear F1 Eagles (GS-D3), Dev\'s keyhole covers, black (painted) J-Spec nose badge[/size]
Quote from: "roger"
Luckily the area in front of me is protected so cannot be built upon. They have totally filled in the village in the nine years I have lived there but the parkland and old village brook in front of me remains  s:wink: :wink: s:wink:
Anyway I better get back on topic with the handbrake. Becuase my other car has an automatic brake I sometimes (like yesterday) forget when switching and drive off with the handbrake on  s:? :? s:?  The 2 pulls so well you don't even notice until you see the red indicator on the dash two seconds later  s:cry: :cry: s:cry:
Quote from: "kanujunkie"hmmm, wonder if i could wire the same thing up on mine  s:? :? s:?
The brake pedal part should be easy. There's already a switch on the pedal for the brake lights. Just route your START-position from the ignition through a relay, which is triggered on by the brake light...
thats what i was thinking, then a new switch tack welded onto the clutch and the wife wont go jumping the car everywhere
Bit off topic but
Quote from: "Liz"
You got a balcony!!
Up north!!!!!!
Quote from: "kanujunkie"problem is i need more feet ...
Ah, another point in favour of the SMT!
Quote from: "heathstimpson"I sometimes (like yesterday) forget when switching and drive off with the handbrake on  s:? :? s:?  The 2 pulls so well you don't even notice until you see the red indicator on the dash two seconds later  s:cry: :cry: s:cry:
If you don't notice in the 2, try it when you've got an automatic with 450bhp!
Quote from: "aaronjb"
is that not normal? hehe ok it was early for me when i wrote that   s:? :? s:?
