Yet another rattle cured I hope
Started by normanh, June 9, 2006, 10:10
normanh
In preparing for my touring holiday of in the North of France this year I have purchased a engine cover mounted rack at great expense. This has highlighted a rattle in the cover that I had not been able to find.
It seems the hinges do have some upwards slack on them which can allow a slight rattle , the movement is I would say undetectable in normal driving unless you have a rack fitted.
Now it seems there is a bit of adjustment in the stops on the body at the back but this does raise the rear edge of the cover to a point where it can be seen much clearer. The correct placement I am not sure of , anyone know?
The simple solution is to use some self adhesive rubber feet that can be bought from a number of places plus the thicker self adhesive foam, seems to have worked for me.
normanh
Quote from: "normanh"Now it seems there is a bit of adjustment in the stops on the body at the back but this does raise the rear edge of the cover to a point where it can be seen much clearer. The correct placement I am not sure of , anyone know?
They are used to finetune the level where it rests, so the correct placement is just that.  s8) 8) s8)
