Water Leak!
Started by Anonymous, September 5, 2006, 13:14
I had a leak in an Opel, wich was caused by blocked tubes that were running from the air intake in front of the windscreen and flooded the area were the fan is. The water travelled thru airpipes in the cabin.
Hope you wil find the leak: water always seems the go where it is least expected.
greetings,
Henri
leon_in_uk
well both drain holes are clean and lead out of the cabin anyway..
there still seems to be water leaking somewhere. the only way im gonna spot this is if i sit in my car and somebody puts the hose on top of my car...
its not a pleasant smell i tell ya
Previous:
BMW z4 3.0
Seat leon cupra mk2
SOLD:
bmw z4 2.0 sport
leon_in_uk
got in my car this morning and checked behind the passanger seat, and there was a slight puddle again... yet there wasnt much rain last night!!
there seems to be water under the carpet, but would this raise to be on top of the carpet??
how do i make it stop?
Previous:
BMW z4 3.0
Seat leon cupra mk2
SOLD:
bmw z4 2.0 sport
Quote from: "leon_in_uk"how do i make it stop?
take the sidevents off, pull the flapper valve off and throw them in a dishwasher, lastly, cut a small v cut out of the bottom of the rubber flapper but do make it very small
leon_in_uk
cant i just rip the flapper off and not put it back on? what will that cause?
Previous:
BMW z4 3.0
Seat leon cupra mk2
SOLD:
bmw z4 2.0 sport
wind noise
leon_in_uk
got ya. so right at the bottom a little hole!!
but how is the water getting to the carpet if you think its just the flap?
Previous:
BMW z4 3.0
Seat leon cupra mk2
SOLD:
bmw z4 2.0 sport
Quote from: "kanujunkie"wind noise
And maybe dust/dirt/crap coming inwards at higher speeds.  s:? :? s:?
Quote from: "leon_in_uk"but how is the water getting to the carpet if you think its just the flap?
the back of the flap gets a sticky layer on it seals itself shut, then although you've cleared the crap out, the water builds up and leaks over the edges.
the dishwasher removes the sticky deposits and the small cut in the rubber is a last chance saloon job. It was a Toyota mechanic that told me about this one, works well
your sure this is water and not fuel?
leon_in_uk
yes defo not fuel..
its smelly, i have asponge in the back to soak it up and drain it out!!
defo rain water.  s:cry: :cry: s:cry:
Previous:
BMW z4 3.0
Seat leon cupra mk2
SOLD:
bmw z4 2.0 sport
leon_in_uk
#36
got in my car this morning and to find loads of condensation on the inside windows and on the inner roof.
anyone else have this?
Previous:
BMW z4 3.0
Seat leon cupra mk2
SOLD:
bmw z4 2.0 sport
I'm getting a lot of condensation the now as well, nothing inside that seems to be wet though, i have checked about.  Sometimes I get drips of water running down from the window seal on both sides but even that isn't enough to make the inside wet.
It's frustrating the life out of me the now as it's taking ages to de-mist the bl00dy windows going to work.
leon_in_uk
umm i still have water on the carpets that why. need to dry them off properly and not just with a sponge!
i might try sponge and hair dryer!!
i heard the other day toyota can look at this problem free of charge, is that true?
Previous:
BMW z4 3.0
Seat leon cupra mk2
SOLD:
bmw z4 2.0 sport
philster_d
Go use a forecourt vaccum cleaner that can almost dry the carpets
leon_in_uk
#40
even if loads of water may go into the vacuum?
Previous:
BMW z4 3.0
Seat leon cupra mk2
SOLD:
bmw z4 2.0 sport
It's not your hover so wouldn't bother about water getting into it  s:!: :!: s:!:
leon_in_uk
#42
i know that, but dont want  to blow it up while im cleaning it... it would be like a bomb explosion
Previous:
BMW z4 3.0
Seat leon cupra mk2
SOLD:
bmw z4 2.0 sport
leon_in_uk
#43
went to a garage yesterday, sucked out all the water and what a job it did!!!
so after all water was gone i decided to do a test. my dad was putting the hose on the car and was inside looking for a leak, there wasnt a visible leak only what seems like the water going through the drain holes and onto the inside body work,
so i thought it may be the flap thingy,, i have pulled that off now too.
it seemed to seap up through the carpet behind the seats...
when it drops from the drain holes, where does the water go? can there be a seal broken??
Previous:
BMW z4 3.0
Seat leon cupra mk2
SOLD:
bmw z4 2.0 sport
philster_d
#44
see I told you
leon_in_uk
#45
you did dude. only thing is, there is still water even thought he drain holes are unblocked!!
what can this be please peeps?
Previous:
BMW z4 3.0
Seat leon cupra mk2
SOLD:
bmw z4 2.0 sport
philster_d
#46
did you take off the vents to see from the outside ?
iirc there are t plugs one inside and one outside
leon_in_uk
#47
yes, took vents off, its like the water drops thrrough the outside then into the panel, and leaks through to my carpets
Previous:
BMW z4 3.0
Seat leon cupra mk2
SOLD:
bmw z4 2.0 sport
#48
There should be a drain hole on the bottom of the chassis rail (between the inner & outer skins)
leon_in_uk
#49
how do you get to the inner side? is this a common source of leakage?
and how easy to repair
Previous:
BMW z4 3.0
Seat leon cupra mk2
SOLD:
bmw z4 2.0 sport
