Where should I take my car for a service?
Started by philster_d, October 9, 2006, 17:24
philster_d
Well my car had been working hard over the past few months and its due its first post turbo service.
Question is where to take it ? Toyota guildford (up the road from me)? or somewhere further eg rogues ?
What do you think do I realy need to use a specialist garage now ?
Philster.
Back to Hungary then Phil?  s:lol: :lol: s:lol:
Well I wouldn't let Inchape Toyota at Guildford anywhere near it. I'd go for Rogue.
I never got to get my car serviced post-turbo, but if I had it would have gone to either my local Toyota place in Bishop's Stortford or to my local friendly garage where I got the brakes/clutch/flywheel done.
Failing that, why not do it yourself? At the worst it's an oil change, coolant change, brake fluid change, and a visual check of the pads and discs, so eminently do-able if you've got the right fluids.
i have, Abbey Citroen, formerly Abbey Toyota have worked on mine several times and have done 1 service. At the end of the day theres no diference in the actual service, you can supply your own oil and filter for them to use of course. They wll then factor that into the cost
Have you only done 5,000 miles since it was fitted then Phil?
