Dyno Results from teh 25th November Dyno Extravaganza
Started by markiii, November 30, 2006, 13:28
Guys, Posted seperately here as it's more performance related.
I've included dyno plots for those that have sent them to me, I'll add more as I get them
Dyno Results
User Name:   Unknown existing SP Customer who was there on the day
Mileage:   25K
Power Mods:   TTE Turbo 7-8PSI
Expected Power:   180bhp
Actual Power:   178.8bhp
Expected Torque:   188 ft/lb
Actual Torque:   215ft/lb
User Name:   Evileye
Mileage:   9K
Power Mods:   Stock
Expected Power:   ?bhp
Actual Power:   138bhp
Expected Torque:   ?ft/lb
Actual Torque:   125ft/lb
User Name:   MuffDan
Mileage:   79K
Power Mods:   Che Header
Expected Power:   138bhp
Actual Power:   106bhp
Expected Torque:   ? ft/lb
Actual Torque:   114 ft/lb
User Name:   Turbo Steve
Mileage:   32K
Power Mods:   Hass Stage II Turbo 10PSI
Expected Power:   220bhp
Actual Power:   214bhp
Actual Torque:   214 ft/lb
User Name:   SimonP
Mileage:   25K
Power Mods:   TTE Exhaust, markiii inlet pipe, TRD Filter, no precats, unichip
Expected Power:   145-150 bhp
Actual Power:   145 bhp
Actual Torque:   129 ft/lb
User Name:   Philster_d
Mileage:   30K
Power Mods:   C2 Power Turbo (V2) 12PSI
Actual Power:   269bhp
Expected Torque:   210 ft/lb
Actual Torque:   246 ft/lb
User Name:   bossman23780
Mileage:   43k
Power Mods:   TTE Turbo 7-8PSI, TRD Flywheel, TRD LSD, C-1 Drive train Pulley
Expected Power:   175bhp
Actual Power:   184bhp
Expected Torque:   160 ft/lb
Actual Torque:   216 ft/lb
User Name:   Gazz
Mileage:   37K
Power Mods:   TTE Turbo 7-8PSI, TTE Exhaust, markiii inlet pipe
Actual Power:   200bhp
Actual Torque:   211 ft/lb
User Name:   Spit
Mileage:   91K
Power Mods:   C2 Power Turbo (V1) 12PSI, Exeddy Clutch
Expected Power:   ? bhp
Actual Power:   267bhp
Actual Torque:   230 ft/lb
User Name:   Chris
Mileage:   36K
Power Mods:   Unichip, Remus Dual Exhaust
Expected Power:   140 bhp
Actual Power:   143.9 bhp
Expected Torque:   130 ft/lb
Actual Torque:   130 ft/lb
User Name:   Loadsawine
Mileage:   17K
Power Mods:   PE Turbo 7.5-7.9 PSI, MWR Chargecooler, Top Secret decat pipe, TTE Exhaust
Expected Power:   180 bhp
Actual Power:   199 bhp
Expected Torque:   170 ft/lb
Actual Torque:   185 ft/lb
User Name:   Heathstimpson
Mileage:   31.5K
Power Mods:   Unichip, TRD Filter, H&S Dual Exhaust, markiii inlet pipe
Expected Power:   150 bhp
Actual Power:   144 bhp
Expected Torque:   135 ft/lb
Actual Torque:   144 ft/lb
User Name:   TommyD
Mileage:   30K
Power Mods:   Stock
Expected Power:   125 bhp
Actual Power:   133 bhp
Actual Torque:   124 ft/lb
User Name:   Leggy
Mileage:   38K
Power Mods:   Cstom Twin Exhaust, Che Manifold, Panel Filter, markiii inlet pipe
Actual Power:   146 bhp
User Name:   FGRob
Mileage:   6.9K
Power Mods:   Ce manifold, Blueflame exhaust, K&N Panel Filter
Actual Power:   147 bhp
Actual Torque:   128 ft/lb
User Name:   markiii
Mileage:   40K
Power Mods:   Hass Stage II Turbo 9.7PSI, Custom Exhaust, Apexi Intake, RPS Streetmax Clutch and Flywheel
Expected Power:   200 bhp
Actual Power:   264 bhp
Actual Torque:   252 ft/lb
and for comparison Phil emailed me his TTE run from Hypersports wwho use teh same dyno as WRC. Phil has a TTE Turbo
Some interesting stuff there that will fuel many lines of debate. It was great to be there when so many cars were dyno'd .
For the record, I think my own boost figures were actually 7.5 to 7.9 according to the charts that Thor produced. ( haven't changed it since they set it up)
Some stonking figures there, guess that reflects the effort that our members go to in setting up their cars.
thanks Nigel I've ameneded that
philster_d
All fly wheel figures ?
If so why dont we use WHP ?
no idea
its often easier to compare flywheel figures as these are the one manufacturers use  (ie what more than 14o are you getting)
it appears that wastage through the 'two's gearbox is around 17% if you wanted to work it out
Conversion factor used to get to flypower on the day was 12% for the '2s (and IIRC 15% for the TVR)
excellent so as Phils big heavy 17" wheels cause more parastic losses I probably put out more power  :-) :-) :-)  in real terms
philster_d
Sure  s;) ;) s;)
Quote from: "spit"Conversion factor used to get to flypower on the day was 12% for the '2s (and IIRC 15% for the TVR)
That's what the WRC guys told me. They reckoned the loss was quite small on the '2 due to the axles being driven virtually straight off the gearbox, whereas the TVR has a short propshaft.
Quote from: "philster_d"Sure  s;) ;) s;)
yep I am
 s:wink: :wink: s:wink:
speaking for the NA boys the big surpirise of the day was the amount of gain people were getting from the che manifold.
With some people running around 133bhp standard the che manifold engines were putting out 145-147bhp with only panel filter changes.
Not bad considering you could get one for less than £200 what with the weak dollar.
EDIT: Except MuffDan whose che header managed to lose him over 30bhp from stock!!! - Something very wrong there!???
You can't beat the exchange rate of "bang for the buck!"
Yep, the Che's headers don't seem bad value do they?  s:) :) s:)
philster_d
I mean I would have even more if I threw on the other wheels  s;) ;) s;)
Purely for reference:
274.6bhp
315ft-lb
Sean, im a stats man, was wondering if you knew what your 0-60 was, etc on the griff also is that a good representation of the kinda power it should be producing?!
i have no clue  s:? :? s:?
Quote from: "bossman23780"Sean, I'm a stats man, was wondering if you knew what your 0-60 was, etc on the griff also is that a good representation of the kinda power it should be producing?!
Weight/horsepower.  s8) 8) s8)
Whats the weight then?   s:lol: :lol: s:lol:
TVR's figures - 340bhp, 340ft-lb - they are WAY over-inflated  s:wink: :wink: s:wink:
275bhp & 300ft-lb is what a healthy Griff 500 should produce, so I'm on the money for horsepower and up on torque. O-60 is in a proven 4.8 - 5 seconds, and the power to weight ratio is 266bhp per ton (vehicle weight is 1050kgs).
Nice   s8) 8) s8)
Quote from: "Slacey"TVR's figures - 340bhp, 340ft-lb - they are WAY over-inflated  s:wink: :wink: s:wink:
saw those figures on the net and thought it was more wishfull thinking!
been thinking again! ...
looking at the dyno results and other TTE dyno's, i wondered why that roughly on average the TTE turbo seems to be in the correct zone of BHP that was quoted origanally by TTE! yet nearly everyones torque figures seem to be well above what TTE say it should have been!
i wonder why this is?
mapping, easier to trim down than tune up
muffdan
Quote from: "simonp"Except MuffDan whose che header managed to lose him over 30bhp from stock!!! - Something very wrong there!???
  s:oops: :oops: s:oops:
Yeah, I had suspisions that I had a blocked main cat, this dyno run was to confirmed it  s:) :) s:)  SP agreed and fitted me their nice down pipe along with a TTET and SP back box earlier this week, the car is a little bit faster now   s:D :D s:D   Wish I had an updated dyno run I could post you, I don't like being the slowest car dyno'd!
firepower
a little bit faster  s:?: :?: s:?:
welcome to the turbo club, numbers are only part of it the driving expierience is the best bit  s:D :D s:D    s:D :D s:D    s:D :D s:D
see you got your sp down pipe and back box , ordered and payed for mine but  im still waiting for it now been told it will be in the new year   s:( :( s:(    s:( :( s:(    s:( :( s:(
01 tte turbo, sp exhaust and down pipe, tte springs 190hp more power soon ? 205lb/ft
1/4 mile 14.6 s @ 90 .55 mph  ( at drag strip )
muffdan
Quote from: "firepower"a little bit faster  s:?: :?: s:?:
Yeah, the car is seriously quick now, I wanted to go straight for the SP240, but Matt couldn't get that done for Christmas. Will be going back in the new year for that and then I'll get a dyno run and see what she's pushing.
The SP exhaust and SP back box do sound nice and look great, there's a fantastic burble when it's ticking over, and sounds great when you wind it up too. Very pleased with the overall package, you're going to like!
