Clean your blocked drains!!!
Started by rob_g_clarkson, December 18, 2006, 10:37
Liz
Didn't Tem say about cutting a V shape in the bottom of the flap to stop it sticking up again?
Quote from: "Liz"Didn't Tem say about cutting a V shape in the bottom of the flap to stop it sticking up again?
Can't take credit for that, it was someone else.  s8) 8) s8)
I didn't wanna risk the electronics I have in the bins, so I wanted to get rid of the issue for good. 4th summer without any signs of water in the car, before that it was a yearly issue...probably cause I park under a tree.
Here's my solution:
 m http://www.mr2roc.org/phpBB3/viewtopic.php?f=11&t=17630 m
evileye_wrx
Well I used the Electric flex method. Forced it down from above until I could hear it was through into the vent space. I rigged up a funnel/ pipe combination to direct the water and used water, poking, water, further poking for a while until it appeared to be running thru and not backing up. I did the same on the passenger side altho there was no sign at all of anything blocking it. Strangely when I took the bin out to mop up any left over water I found it was completely bone dry. The only water inside the car had been pools in the two lowest parts of the plastic bin, very odd.
Still it has pissed down severely today so I shall see what the bin looks like now.
Phil
Phil
mr2jw
seasonal bump!   s:roll: :roll: s:roll:
black 2000 roadster | devs keyhole covers | devs tbl visor | pre-cats removed | crystal side repeaters with chrome surrounds | lt short antenna | jdm front badge | jdm wheel centres | mr2roc sticker |
and lots more to do!
Hi John, and welcome to the site!
I think your research refers to piped drainage in houses. There arent really any comparisons with the cars drainage system, other than that air circulation promotes drying out of the system, a good thing for preventing fungal growth.
The UK weather tends to give the system a good flush out an an irregular basis, so as long as the drains are cleaned out occasionally, no problems should occur.
He was a spammer D1ck and has been banned now.  s:) :) s:)
LOL @ D1ck
nathanMR2
Bless   s:oops: :oops: s:oops:
 s:oops: :oops: s:oops:    s:oops: :oops: s:oops:    s:oops: :oops: s:oops:  Only trying to help! I dont know much, but I know about drains!
