tte turbo boost
Started by firepower, January 8, 2007, 22:44
there were 2 maps 180 and 200
only the 180 was sanctioned for release
now i understand!  s:roll: :roll: s:roll:
if only they could have sanctioned the 200 then with extra bits added like a down pipe it could have be pushing even higher! shame!
200 would have been pretty close to teh limits of teh injectors so add all teh exhaust and induction mods on and you'd have been in teh same place SP were with teh 240
i.e needing bigger injectors and teh ability to remap it to cope
i suppose, but if you'd ignore the induction side and just changed the exhaust an DP then i think i would have been happy with that, and i dont think it would have need a remap?
firepower
#204
just fitted a boost gauge and been for a blast , when the car was dynoed at hyper sports i was told the car was running low boost 0.3 bar i think they said.
my boost gauge is hitting 0.6/0.7 bar when i floor it and the only thing i have changed is the standard exhaust for the sp dp and back box could this have made the difference or is my gauge faulty  s:?: :?: s:?:
01 tte turbo, sp exhaust and down pipe, tte springs 190hp more power soon ? 205lb/ft
1/4 mile 14.6 s @ 90 .55 mph  ( at drag strip )
Some gauges might be out a bit, but 100% difference to the dyno reading? I'd be very surprised unless the gauge came from Disneyland!
Possible kink in the boost gauge line? Or was the gauge not reading right on the dyno at HS?
#207
I'd heard there was a figure of 5psi linked to your kit, but didn't realise that came from HS. They tapped into your boost line when we weren't looking?  s:shock: :shock: s:shock:
Could you possibly get a higher boost peak if you gun it on the roads in a lower gear? Just guessing mate. Know nowt 'bout turbos & dynos  s:? :? s:?
Possibly, I know my old car used to peak at just over 10psi in 1st gear at the redline, and then hold 9.5-9.7psi during regular use, but then that was with the Profec acting as a boost controller: I don't know about regular wastegate pressures.
#209
If you don't have adequate boost control then you should see the highest pressures in the higher gears - when the load on the engine is highest.
Quote from: "markiii"As for why t never made the final version of the kit, we still don't know I suspect it was uneccessary at 7psi of boost. i.e the stock tube can flow enough air
In that case the bigger pipe will do nothing at all for any NA car then as air flow is already sufficient, likewise with an apexi or the likes? (plus of course an open filter loses the CAI effect of the closed oem system
Quote from: "markiii"or it was a noise issue as alluded to be Gerald.
my mate who worked at toyota told me this when I bought my first roadster, he said the restriction was there to change the noise due to restrictions in some countries apparently.
muffdan
#211
my car has no pipe   s:shock: :shock: s:shock:
Seems to go ok but I should imagine I'm sucking in some seriously hot air though.
Quote from: "muffdan"my car has no pipe   s:shock: :shock: s:shock:
I'll give you the standard pipe free of charge if you want it, all you have to pay is postage  s;) ;) s;)
muffdan
#213
thanks Richie, although after following this thread I think I might go for one of Markii's pipes! Seems the turbo will benefit from it.
When you go SP Stage II the air box goes in the bin to be replaced by a induction kit so there is no where to put the Mark iii pipe.
muffdan
#215
excellent.
This confirms my belief that the missing pipe is infact a sign that my car wants the SP240 package.
I'll just have to tell my wife that it's not good for my engine to be driving around with a missing pipe, and that I need to the SP240 to fix as soon as possible.   s:D :D s:D
Quote from: "Silverstone Performance".....The max permissible boost pressure is 9.72psi - which I don't think we've seen exceeded ?
You have now.....
By my calculations that's 10.15 psi I'm running!
#217
Quote from: "Matt"
You have now.....
thats reading 0.71 which would make it 10.44PSI  s:wink: :wink: s:wink:
SimonC_Here
#218
Google makes 71kPa = 10.30psi (10.2976794)  s;) ;) s;)
 s:D :D s:D
Simon
#219
that'll be based on 0.7 then Simon  s:wink: :wink: s:wink:
SimonC_Here
#220
70kPa = 10.1526416PSI
Gotta Love Google conversions!
Simon
Quote from: "kanujunkie".....thats reading 0.71 which would make it 10.44PSI  s:wink: :wink: s:wink:
  s:shock: :shock: s:shock:   Even worse!
Car's running like a dream though.... I'll mention it next time I'm up at SP.
Liz
#222
Careful its not running lean - mine was when it was boosting like that!  Glad to see you finally got that boost gauge plumbed in though!
Quote from: "Liz".....Glad to see you finally got that boost gauge plumbed in though!
Yeah, sat under the bed collecting dust for 10 months!
#224
Quote from: "Liz"Careful its not running lean - mine was when it was boosting like that!  Glad to see you finally got that boost gauge plumbed in though!
should be fine Liz, TTE is MAP based mapping
