another manifold/turbo seperation
Started by kanujunkie, January 20, 2007, 14:08
#75
YEP!  s:roll: :roll: s:roll:
I've not run a gasket between the manifold and turbo or turbo and downpipe.
Straight metal on metal no leaks at all.
Use "belleville" (fancy word for a cupped serrated spring) washers all around.
If the flange metals are of similar type, thickness and flat then a gasket just adds  a potential point of failure.
If the gasket burns thru, the threads lose their bite. Heat and vibration do their thing .....blah blah blah  s:lol: :lol: s:lol:
Perhaps your EGTs are exceedingly high?
#77
could be, i've got no guage to check that out, think i'll get her into Thor asap and get them to check everything out, i'll run the trackday at a sensible boost level
popped to nissan this afternoon
and thanks again to arron 14495-17F00 is teh correct number
£2.30 per plate and about teh same for teh nuts
#79
must order some too, one of the manifold studs keeps comeing loose  s:? :? s:?
took the chance and ordered you a set
#81
That's what I call service  s;) ;) s;)
#82
your a gem Mr.Jones  s:D :D s:D
right I collected these from Nissan and can confirm teh part numbers are
Plate lock (2 needed per turbo)  Nissan Part no 1449517F00     £2.30 each
Nuts (4 needed per turbo)  Nissan part no 144320B700   £2.10 each
they are identical to those used on teh TTET
I'm not 100% sure that you need these particular nuts as tehy look nothing out of the ordinary however Stu will confirm when he's tried it  :-) :-) :-)
philster_d
Re:
#84
Quote from: "markiii"I'm not 100% sure that you need these particular nuts as they look nothing out of the ordinary however Stu will confirm when he's tried it  :-) :-) :-)
Stu did they work out ?
