Clutch & flywheel
Started by Tem, November 6, 2003, 11:34
My clutch is very worn...it has already been scraping the flywheel...and I don't think I want just a set of new stock parts.
Didn't find much with search...does anyone have aftermarket parts and how do you like them?
I'm not sure anyone here is, Tem - some of the guys on SC are running TODA flywheels and uprated clutches, but I'm sure you've already looked there   s:wink: :wink: s:wink:
I recall SteveJ mentioned that mph has a lightweight flywheel.
Yeah...I'm just browsing SC...just curious about "local" ppl  s:) :) s:)
mph
Quote from: "Tem"Didn't find much with search...does anyone have aftermarket parts and how do you like them?
If you're not running more power, I can't really see the point in using an uprated clutch plate. However, since you're in there replacing the clutch plate (with whatever), you might as well replace the flywheel with something significantly lighter.
I'm using the one that PPE Engineering sells. Not quite the lightest, but is half the weight of the stock item. The SMT isn't thrilled with the uprated clutch plate but does pretty much cope with it, while it doesn't have any problems with the flywheel.
Overall I do really like the effects the lightened flywheel has, but they may not be for everyone's taste.
'06 Black MR2 Roadster
'03 Red Lotus Elise 111S
Quote from: "mph"If you're not running more power
I'm not...but I see a TTE turbo in the future, or something else if that fails. So I'm just preparing, while I have to change parts anyway.
Quote from: "mph"Overall I do really like the effects the lightened flywheel has, but they may not be for everyone's taste.
I'm assuming the main benefit is that it allows the engine to rev up quicker, why do you think some may not like it? (just interested!)
Quote from: "Slacey"why do you think some may not like it?
Some say it's easier to stall the car on launch with one...which is true, if your typical launch is letting the clutch go at idle without touching the throttle  s:lol: :lol: s:lol:
GSB
I think theres a UK based guy on SC whose been tyring to get rid of a lightened flywheel and uprated clutch for quite a while. He's also got the LEDA suspesion set for sale if I recall correctly.
GSB
Here it is! http://www.spyderchat.com/phpBB/viewtopic.php?t=7255
Doesn't say if its sold or not though...?
QuoteTODA Lightweight Flywheel £175
Blimey! How much are they new?!   s:shock: :shock: s:shock:
New TODA flywheel is listed as $450...that would be roughly £225.
Quote from: "Tem"New TODA flywheel is listed as $450...that would be roughly £225.
Thats a lot of money for whats essentially a big cog!
Yeah  s:lol: :lol: s:lol:
Well, the JUN flywheel is 4.5kg for $325... (TODA is 4.4kg)
Then again, TRD is 4.5kg for...are you sitting down?...$900  s:shock: :shock: s:shock:
(TRD price is with shipping+taxes though)
Typical TuRD ripoff price I see...   s:roll: :roll: s:roll:
mph
Quote from: "Slacey"I'm assuming the main benefit is that it allows the engine to rev up quicker, why do you think some may not like it? (just interested!)
Yes, the engine revs much quicker - and equally, there's much more engine drag when you take your foot off the accelerator. Thus, balancing the throttle is a more delicate affair with a lightened flywheel.
My non-engineering understanding is that a lighter flywheel doesn't have the same inertia as the stock one, meaning that the forces generated through the crankshft by the pistons are not dampened or smoothed out resulting in a 'rougher ride' from the engine (BTW 'ride' is the not right expression but am struggling to find a better one). The upside is the lower inertia  means the flywheel soaks up less of the force/power generated by the engine, meaning a bit more energy than before is transmitted through to the wheels quicker resulting in quicker acceleration .... I think   s:? :? s:?
Quote from: "Tem"
I have enough problems not stalling when pulling away with a stock drivetrain.  Shudder to think what I'd do with a lightweight one.
I guess I'll be going for the TRD parts...Teiwa gives a 20% discount for them  s8) 8) s8)  (and were the fastest to reply, I'm in a hurry)
TODA Flywheel 4.4kg 390e
TOMS Flywheel 3.8kg 450e
ACT Clutch Sets roughly 300-350e
TRD Flywheel 4.5kg 350e
TRD Clutch Cover 170e
TRD Sports Facing Clutch Disc 100e
Shipping for the three 180e
mph
Don't forget you'll need to replace the flywheel bolts - so see if you can get those thrown in for a discounted price too, they ain't cheap!
Can't they reuse the current bolts?
"It is required to use Toyota Genuine fly wheel set bolts."
mph
Nope, they're once only use as you stretch them when fitting.
Quote from: "mph"Nope, they're once only use as you stretch them when fitting.
Now I'm confused...some say it's ok to reuse them, if you use Loctite or some other "thread glue"...
mph
The workshop manual marks them as "Non-reusable part". The procedure for tightening is that use first torque them to 49N-m (500kgf-cm, 36ft-lbf) then turn them a further 90 degrees.
Considering the danger if even one of the heads sheared off, do you really want to risk it?
Quote from: "mph"Considering the danger if even one of the heads sheared off, do you really want to risk it?
No.
And Toyota was very clear about this as well, they said there's no sense to reuse the old bolts.
