o2 sensors
Started by Anonymous, February 6, 2007, 14:53
and the fuse?
Hugo
Quote from: "kanujunkie"and the fuse?
Fine not blown, car now idles at 1700rpm when cold  s:cry: :cry: s:cry:
2003 MR2 Lagoon blue A/C/leather [ SOLD]
2003 TVR Tamora,[373 bhp]
2006 Fiesta ST150.now sold. 2000 Ford Puma Millenium number 64 of 1000
do yourself a favour, get one of these
 m http://cgi.ebay.co.uk/OBD2-OBD-II-2-CHE ... dZViewItem m
and check the codes yourself, theres still a possibility that you havn't changed the correct one. There is also the possability that the ECU has been damaged although this is extremely unlikely, get a scanner and give yourself an idea of whats going on
Hugo
Quote from: "kanujunkie"do yourself a favour, get one of these
Thanks Stu
Where does that reader plug in, some where in the engine bay i presume?
How do you find out what the code means, the Mr T hand held jobbie actually tells you what the fault is, this one just gives letters and numbers i believe, got a O2 socket today, draper for £4.99. I`m half way there  s:) :) s:)
Quote from: "Hugo"Thanks Stu
it plugs in by your right shin bone and the unit comes with a book of what the codes mean
SimonC_Here
But only if you're sitting in the drivers seat!   s:lol: :lol: s:lol:    s:wink: :wink: s:wink:
Simon
Quote from: "SimonC_Here"
Simon
smart arse!  s:wink: :wink: s:wink:
Hugo
Received my tester yesterday, only one fault code now po141, got a new sensor and just about to fit it and take it out for a run, that will be all 3 O2 sensors changed so as long as i`ve done the job properly we should be OK,
What idle speed do you all have at cold/first start? ours is still at 1700/1400 rpm till warm then 1200 till hot then 950 after, in normal running is the norm?
Hugo
So far so good  s:? :? s:?   2days and 100 miles and about 3 cycles and the light remains off  s:P :P s:P
RacingSnake
That's encouraging Hugo - still waiting for MrT to send my garage the post-cat sensor as they have supplied the pre-cat twice now   s:roll: :roll: s:roll:
enid_b
i got one of these sensors off ebay.
just about to fit it today and notice it only has 3 wires on this.
i think its the earthing wire, can anyone help regarding this, or do i need to get the proper one sent out.
a speedy reply would be good.
ta
E
