3sgte Engine
Started by Anonymous, March 8, 2007, 23:24
hi their i was direct to this forum from admin member of spyderchat.com. i did search to see if i can find the answer on my own but no luck.  i have 02 spyder and a extra 3sgte engine 3rd gen with a hks stroker kit. i just wanted more info on this swap i'm just working with what i have. trust me if i had a k20 or 2zz ill install that but 3sgte is in my shop and i want use it in my spyder.
need help before i start the project any advise or would help thnxs
you need to speak to Patrick at Rogue Motorsport
 m http://www.roguesystems.co.uk/static/home.aspx m
if you pm Rogue on here you'll also get Patrick. He is 90% of the way through an install, i beleive its not as simple as popping it in and connecting it up, i know for a start that he's had to reposition the beam that has the boot release catch on it. Give him a bell anyway an i'm sure he'll help you
also heres his origional link, no technical data, just some pics
 m http://www.mr2roc.org/phpBB2/viewtopic. ... highlight= m
