DESPERATLY SEEKING HELP! PLEASE!
Started by Anonymous, April 7, 2007, 10:44
First off, a HUGE thanks to anyone who can make it to the bottom of the very long post!
  s:cry: :cry: s:cry:
right where to start, i just bought a 2000 mk3 MR-S with 36,000 miles on the clock. and i took it for a test drive and it had a rattle that the guy told me was a heat sheild rattle (i thought it was the cat) but he said it was a heat sheild rattle. (the guy is a senior salesman for alfa romeo, i know this for fact! and he'd had the car for 2 years) So i ran it home all the way from scotland (dundee) i live near hull! and all the way back it was rattling about 3500 rpm. i got home and asked my stepdad (a mechanic) to have a look at the heatsheild and he had a look around and said that the rattle is coming from the back of the engine! (To describe the sound, it sounds exactly like a rickety diesel engine.) and it seems to be doing it more now! now im panacking, what could the rattle be? is the timing out? has anyone heard of this before or had it happen to them? its strange as theres sod all mileage on the car! PLEASE, PLEASE HELP! UPDATE: i have taken off the tensioner belt and the rattle is still there! took off some of the plugs clynder 1 and 2 and put a 8mm bit in the ht cable end, so the car would still run. and the rattle still there! it sounds like the rattle is coming directly from the top of the engine from cylinder 1 to be exact! this is rearly panicking me as ive only just bought it! i dont know if its using a lot of oil as i dare not drive it incase i do more damage! and if i need to drive it back to where it came from its got to last 400 miles!!  JUST out of intrest how much will i be looking at for a new engine and where would i be able to get one from? thanks for any help that can be offerd.   s:cry: :cry: s:cry:
UPDATE: I Did about 400 miles back from scotland in it and i cant see any diffrence in oil level. i think the power is still there but i cant be sure as id never driven one before! (i was manily drivng back at 70 mph but did boot  it some times  s:) :) s:)  and the pick up from 70-100 was impressive) and i was used to a mr2 rev 1 turbo!! the tapping is pretty loud and sounds like its coming from the cylinder 1 part of the engine! because the car is so low i could only get my arm under it and i was feeling about (D'oh! yeah right its hot!) and i put my hand on the sump and as the car reved to about 3500 rpm and the ratle started, i noticed i could feel the rattle on the sump! now even with my LIMITED experence with cars, i think theres no heat sheild around that area to be causing that is there? i spoke to one guy on the phone and he said a common problem with the early mr-s is that cylinder 1 could oval bore out and the piston could crack! causing it to sound rattley (more like a deisel engine to me) ALSO the guy who is picking me up for work has a 1.8 celica on a N plate and his sounds the same at about the same revs in 4th! but his is bearly noticeable! its quiet. I did buy the car private, but the guy told me he was a trader, and i even have the address of the place where he works! maybee i could use that to my advantage, i didnt sign anything to say sold as seen. And when i told him about the problem he says hes not intrested. am i fooked?  thanks to all who could be arsed to read this. cheers.  s:cry: :cry: s:cry:
did you check teh precat thread as I advised?
Liz
Hindsight is a wonderful thing, but personally I wouldn't of bought a car with an unidentified rattle and gone by the word of the seller as to what it was.   s:? :? s:?  Found this link for you...question 12 is which applies to you.
 m http://www.dti.gov.uk/consumers/fact-sh ... 38071.html m
Mind you having said that I bought mine from a trader and a problem occured after I bought it which I hadn't noticed on the test drive - ended up fixing it myself!  s:? :? s:?
I think that you are barking up the wrong tree with going after him at work, they won't be interested as what he does outside and his dealing with selling his car has nothing to do with his work.
Maybe there is a owner in your area who you could meet up with and for them to have a look, fingers crossed for you that it is not serious. Good luck.
Hmmm. Now that there's a bit more story I'm not sure if its as simple as the famous Cat heatshield rattle that we discussed via PM  s:? :? s:?
I wonder if a compression test across the four cylinders would help lead to a diagnosis and (hopefully) rule out something very nasty? (sorry, I'm no expert, but one of the other members might be able to confirm if this is worth doing...).
most definately worth doing
most serious engine related  problems usually result in a knock,  rattle or rumble that will increase / decrease with engine revs (big end, little end, main bearings top end problems etc). For something to happen at a particular rev point would suggest a balance problem causing vibration / rattle. Would an oval bore cause this? If it would then, given the kind of gap required, the oil loss / smokey exhaust would imho be certainly noticable.
Agree with the experts about the compression test
does the rattle sound metallic? or is it muffled in sound, if you can hear a mettalic rattle then its external of the block
Quote from: "kanujunkie"does the rattle sound metallic? or is it muffled in sound, if you can hear a mettalic rattle then its external of the block
sounds like your hitting the block with a hamer sound! like a diesel engine sound. but only as you go over from acceleration to deceleration, when stood or driving.
If it sounds like a diesel, then its a knock.
If it knocks at a certain point when you accelerate and then when you deccelerate then you need to rule out piston slap caused by bore wear.
Normally though this would tend to go away as the engine warms up and the components expand (and as said before, this would vary to some extent with engine revs, but not as much as with bearing problems).
Get peace of mind and do a compression test
Don't want to complicate this, but ther's loads of stuff on spyderchat about timing chain rattle.
Thanks for the posts guys, i couldnt stand it any longer and went for a steady drive, i noticed that the rattle/knock (or what ever where calling it) only appeares when i put the accelerator down about 2 inches anything over that and it comes back. when the cras warmed up its more noticeable as well it seams, you can hear it just slightly when its ticking over. illget a compression tase done and tell you what i find.
If it gets worse as it warms up then it is probably not piston slap due to bore wear. My money now would be on the timing chain.
I would be tempted to trust the garage here. Any good mechanic should be able to diagnose the source of the problem. You need somebody to recommend a good garage in your area.
stv2100
Try a compression test, as a blown head gasket can surprisingly sound like a mechanical knock. I had a head gasket go on an astra and it didn't leak any water and no gunk in the oil. It did sound like a heavy knocking/ rattle though.
Silver 00, Hardtop, corky\'s breast plate, BC Coilovers, FTSB
Quote from: "kingmodest"sounds like your hitting the block with a hamer sound! like a diesel engine sound. but only as you go over from acceleration to deceleration, when stood or driving.
As someone else said you should really get the car to an experienced mechanic - it's very, very difficult to diagnose noises over the internet..
But - a rattle on decelleration would normally point to little-end bearing failure.. that would, I think, be a first in a 1ZZ so I'd be more tempted to think big end bearing shells, a common failure point if you end up with a low oil level after pre-cat or oil control ring failure.
Of course, if it's not as bad as any of us are thinking it could be the old serpentien belt-tensioner failure, which is very common indeed (and most Toyota garages would know what you're talking about if you mention that to them - it's the little damper shaped thing, right hand side of the block) - tends to sound a bit diesely at idle and low-load.
Like I say - you really need someone who knows engines well to be there to physically listen to it, better still someone who knows 1ZZ and knows what their various death throes sound like..
Quote from: "markiii"did you check the precat thread as I advised?
I did my friend, thanks. looking at it i dont think thats whats happened to my car! (im hoping) but as soon as i get the car sorted that is DEFINATLY on my list of things to do! smash out the pre-cats  = have a happy and long life with your car. got it!  s:D :D s:D
I'd check them anyway
if tehy are missing in action chances are they caused your issue
Quote from: "markiii"I'd check them anyway
if they are missing in action chances are they caused your issue
im hoping to get it into to my local toyota dealer today, and get them to look around it. hopefully they will be able to tell from the sound if theres a big prob or not. as its gonna cost me quite a bit i would of thought just to have someone take off the manifold to tell if the pre-cats have gone!  s:( :( s:(
3 bolts hold teh manifold bottom to the cat
remove push the cat out pf teh way and look from underneath
from above remove 02 sensors and check via teh holes
Hey guess who is having the exact same problem and has no idea wtf it is... yes.. ME!
makes a fucking anoying drilling sound.. when you put your foot down about 2 inches.. and then it stops when you take it off.. it comes from the top of the engine.. its not the heatshield or anything its defo inside the top end of the engine.. i too am also going to a toyato garage to get it looked at..
Brad1208
Quote from: "Jamie"Hey guess who is having the exact same problem and has no idea wtf it is... yes.. ME!
makes a f*****g anoying drilling sound.. when you put your foot down about 2 inches.. and then it stops when you take it off.. it comes from the top of the engine.. its not the heatshield or anything its defo inside the top end of the engine.. i too am also going to a toyato garage to get it looked at..
Yep me too! When you taking it? You'll have to keep me posted on what they say because its going to be thw weekend before i can get mine in anywhere and would be good if i could get some idea as to the problem....and more importantly the costs   s:? :? s:?
[size=75]2002 Black, Private Registration Number, Red Painted Calipers, Rear Spoiler, Black J-Spec Nose Badge, Lockwood Door Sills, PreCats - Gutted[/size]
log onto spyderchat and search timing chain rattle in the maintenance forum
This will either make you feel better or worse
Brad1208
You got the link? SpyderChat wont serach for me, just keeps throwing a load of SQL errors
 m http://spyderchat.com/phpBB2/search.php?mode=results m
search 'timing chain rattle'
check 'search all items'
forum = 'care maintenance and troubleshooting'
I'm too computer thick to get it closer than this
Right got it to the toyota dealership yesterday and they had a look round it, took it out for a drive and even got there top mechanic to look at at. after about an hour they scratched there arse's and siad they dont know whats wrong with it, and that it could be the timing chian, they would have to take the engine appart. There was something i ment to say in my previous posts and that was that the car when warmed up is ideling at about 200 rpm! its sat at the little mark near the 0 rpm (you know the one i mean!) could that have something to do with the timing chain? then asked the question is it an import? to which i replyed YES and was quickly told they couldnt work on it, and its impossible to get parts for! Now i hope they where lieing as i may very well need parts in the future! does anyone know where i can get parts for an import from? i may even need an engine at som point where do i get one of them? does it have to be an import engine?
repeat after me
talking
out
of
arse
other than a few minor things like ecu, bumpers e.t.c 99% of teh car is teh same worldwide, you need to find a more enligtened dealer
