charge cooler install
Started by kanujunkie, April 18, 2007, 20:28
As you may or may not know, Mark and myself are about to embark on a chargecooler install. I've started this thread so that we can get the communities advice and thoughts on things and problems
to start with were going to be move the stock coolant bottle, does anyone think there will be too many problems if its dropped by 1"?
SteveJ
Simple answer to the bottle question - Yes there will almost certainly be problems with it blowing coolant out when hot resulting in air getting drawn back in when the car is cold and the coolant has contracted  s:( :( s:(
With the turbo I would like to be able to raise the bottle up but there isnt room to do it.
Peter Wright
To start with for the more ignorant members like myself, what is a
chargecooler and what does it do
Pete
problem is i have to move it for the CC coolant bottle to go in but at best it'll be 1cm lower than stock  s:? :? s:?
SteveJ
Without seeing what you have bought and are proposing for the install I'm not sure what to suggest, but given that the coolant always drops to the minimum mark after a while no matter how often you top it up (because the excess gets blown out when the car gets really hot which is always a possibility with the turbo), I would suggest that unless you introduce a larger capacity bottle, then lowering it is going to be fraught with potential airlock problems  s:( :( s:(
Quote from: "Peter Wright"To start with for the more ignorant members like myself, what is a
Pete
same as an intercooler
but done using water
Quote from: "SteveJ"Without seeing what you have bought and are proposing for the install I'm not sure what to suggest, but given that the coolant always drops to the minimum mark after a while no matter how often you top it up (because the excess gets blown out when the car gets really hot which is always a possibility with the turbo), I would suggest that unless you introduce a larger capacity bottle, then lowering it is going to be fraught with potential airlock problems  s:( :( s:(
tend to think your right
SteveJ
I would have thought the location of the inter-cooler header tank should be fairly flexible - the only restriction is that it must be the highest point in the system to capture any air bubbles.
Given that the temperature of the coolant is unlikely to increase much, then you wont need the header to act as an expansion tank either (any expansion should be absorbed by the flexible tubing running forward to the rad). This should result in a relatively small unit that can be hidden just about anywhere in the engine bay (away from extreme sources of heat obviously  s;) ;) s;)  )
I was thinking of siting my header tank behind the battery. Not such a brilliant place for topping up, but easier to get the height you need to fill the CC system. I just need to get a bit of hosing and then I can be resiting mine while you install yours, so we can all have fun in different locations!  s:lol: :lol: s:lol:
Where did you source your hose?
Nige, nicy easy place for you is where teh charcoal canister used to be
had a quick look tonight and reckon that there might be room for both in Stus case  :-) :-) :-)  subject to a small modification of teh bracket
I like that idea Mark. There is loads of space on that side in my engine bay. Just need to get a few metres of suitable hose now.
Resiting will tidy up the install no end.
Quote from: "markiii"Nige, nicy easy place for you is where the charcoal canister used to be
so you reckon we should loose the charcoal canister then Mark?
do we nee to do anything when we pull it out then? or just unplug it?
Quote from: "kanujunkie"so you reckon we should loose the charcoal canister then Mark?
I just put the lines together.
There's a VSV on the intake pipe, which opens under strong vacuum and creates vacuum in the tank through the canister. The canister is there only to catch gas fumes and it's not that important. But the vacuum in the tank might have a reason?
cheers Tem, i seem to remember that Dan ran his without the canister, i'll give him a bell later and see if he had any issues
dan still used teh canioster but had the lines from it purged outside rather to teh VSV
Nige has his removed altogether
however I reckon thewre is room for both if teh bracket isd modified
SteveJ
Martin ran his PE without the vacuum lines connected and found that the fuel gauge was a little unpredictable - it would read anywhere between half full and empty when the tank was almost dry   s:? :? s:?  This almost caught me out on the way back from Anglesey (I'm glad I refilled the jerry can before setting off   s:) :) s:)  )
Quote from: "markiii"however I reckon thewre is room for both if the bracket isd modified
you've not seen the tanks yet though  s:? :? s:?
btw i have some 90deg stainless brackets for us to use, courtesy of the kitchen modifications  s:wink: :wink: s:wink:
Are you going to tile the engine bay as well Stu?  s:lol: :lol: s:lol:
Quote from: "loadswine"Are you going to tile the engine bay as well Stu?  s:lol: :lol: s:lol:
could be an interesting install  s:lol: :lol: s:lol:
pre-rads just turned up, unfortunatly i now need to find a px switch for it to plug the sensor hole up  s:roll: :roll: s:roll:
anyone know any sources of 100mm Dia p-clips?
need them to mount the CC, first though was motorbike exhaust hangers but i'm either finding they cost a bomb or are too large
You could try the universal band from these folks who do supplies for kit cars. Their P clips only go up to about 60mm, but the bands are more dimensionally flexible. ( you can tell I've had a glass of wine or two!)
 m http://www.nfauto.co.uk/consumables.htm m
Pah, you engineering types.. giant tie-wrap not good enough for you?   s:P :P s:P    s:wink: :wink: s:wink:
cheers for the idea Nige, i'd already seen that but i'm trying to use a p-clip that will support the CC from all sides properly and i wasn't convinced that that strap type material would. I'd found that micron exhaust cans are the same diameter as the CC but the hangers cost over £20 each!
as for tie-wraps!  s:roll: :roll: s:roll:
Surely (with the strapping) you could 'form' it around the CC so it makes an almost complete circle, then bolt it to the bodywork, and then slide the CC in?
Or something along those lines.
C'mon, tiewrap it on y'great jesse.  s;) ;) s;)
no argument on that one, i could definatly form it, however the metal is a perforated material for a start thats plastic coated and over time it will marr the finish of the CC and damage it in time. Proper p-clips have heavy rubber in them and will step the CC away from the metal behind and i'd much rather use them
