Wideband test
Started by Tem, June 28, 2007, 08:19
I saw that, too.    LC-1/XD-1 rules.    s:) :) s:)
Indeed - it's what I have on my list to buy  s:) :) s:)  (XD-16)
oooooooppppppsss, my PLX buy wasn't so good then  s:( :( s:(
Quote from: "kanujunkie"oooooooppppppsss, my PLX buy wasn't so good then  s:( :( s:(
I'm afraid it wasn't. If it can be off for +-1.0AFR, I don't think you should trust it too much.  s:? :? s:?
Another poor one is the Dynojet one. If it takes half a second to get a reading, imagine what happens when you're logging and go through few cells in half a second. You won't have the results in the proper cell and if you tune based on that, you're gonna have issues.
The article also raises another interesting point. The sensors do go bad over time, which affects the reading. If a sensor can't calibrate itself, how can you ever be sure if your sensor is still ok? Aged sensor combined with poor accuracy can be deadly. Say you're targeting 12.5 and end up with 14. BOOM!
