Who's fitted a power steering pump?
Started by hywel, July 19, 2007, 19:43
hywel
Dealers are quoting several hours and £100 or so - it looks like it should be easy though - one spyderchat guy reckoned on 30 minutes and easy.
Can anyone help please?
Hywel
My local garage (none Toyota) did one for me a couple of years ago and only charged me £35 so it can't be a big job! Sounds like they're trying it on to me?
i can supply you with the fitting guide if you want
hywel
Quote from: "kanujunkie"i can supply you with the fitting guide if you want
That would be brilliant. Cheers.
Hywel
hywel
Thanks, Stu, all received.
The only section that refers to it says Bleed Power Steering System (SR3) - do you have this page by any chance?
its in that file i posted!
look at the top right corner of the first page of the pdf called 03- Power Steering fluid - bleeding.pdf
hywel
Quote from: "kanujunkie"its in that file i posted!
Oops. Cheers very much. (Note to self: RTFM.)
i need a new power steering pump fitted! The garage are qouting 1500 pound!!! does anyone know where i can get one cheaper???? please??????????
hywel
Quote from: "bex82"i need a new power steering pump fitted! The garage are qouting 1500 pound!!! does anyone know where i can get one cheaper???? please??????????
That probably consists of £950 for the pump and £500+ for fitting - both absurd. There are various online breakers yards that'll charge between £150 - £300 for the pump, whilst fitting takes an hour and is a piece of p**s.. I bottled out, but my nearest garage did it for £50.
Hywel
