1zz turbo 1.81L GTK450 updated 19/02/12 pg5
Started by MR2 super GT, August 13, 2007, 21:22
MR2 super GT
#150
Not a lot. 16psi and 300hp
New build is holding up fine at 24psi
when I\'m not in traction, I\'m in action
MR2 super GT
#151
Finally got the car mapped and ruining without any issues. My Sard fuel regulator was faulty after only a few thousand miles and it was genuine! Had a melted vacuum pipe which was preventing the turbo spooling properly and a fouled up O2 sensor from running rich on the previous attempt at mapping it. The previous tuner didn't workout all the little issues and kept trying to map the car in a roundabout way. So results are 360hp @ 6200 and 310 lbft @ 5900
MR2 super GT
#152
tomaky
#153
Happy days  s:) :) s:)
Westfield Seiw
Ex - 2005 Porsche Cayman S
Ex - 2003 Sable
Ex 2004 Blue  Roadster RIP
ChrisGB
#154
That'd be fun to drive then!
WOW talk about resurrection!
MR2 super GT
#156
Either like a Phoenix from the flames or a zombie that won't die lol. Yes Chris it's a real rush every time I drive it. Also for future reference the 2 previous builds that failed could have been due to insufficient head bolt torque as
Previously mentioned or air in the charge cooler setup which was left unchecked and caused a massive spike in temperatures under boost. These are the conclusions I've come to. Problems now sorted by using clear hoses at the highest points in the charge cooler setup to make sure there is fluid in the system. Next I might get 1000cc injectors and send the turbo to Turbodynamics for upgrading
1000cc injectors?!?!?!? Holy sweet mother of chickens...
MR2 super GT
#158
Well I'm on 630cc at the minute and they could still do. I'm running 30psi so really can't run any higher on super unleaded so turbo upgrade is only way I'm gonna get more power.
Hard times mate. Hard times  s:) :) s:)
I suppose if you must increase the turbo size, what's a man to do?
Quote from: "shnazzle"Hard times mate. Hard times  s:) :) s:)
Get something that comes on song a bit earlier if you can.
