Whining noise!
Started by Anonymous, November 15, 2007, 19:02
Hi folks.Got a noise coming from the front of the car,which sounds like a flat tyre.All four are at correct pressure,so i know it's not that. It doesn't matter what speed i'm doing,this noise is constant.Could it be wheel bearings perhaps? Just wondered if anyone could help me out? Thanks a lot.
Whining noise or a squealing noise?
First thing to check is the brake pads, they have springs attached which "squeal" when your pads are down enough to need changing.
its more than likely either that or a warped disc. strip the brakes down and rebuild them, should only take about 30mins a side at most
