Windback Tool
Started by Innocent, January 11, 2008, 17:09
Innocent
I'm fitting new pads tomorrow but dont have the windback tool. Any ideas where i can get one from? Halfords?
Yep - Halfrauds should have them, about £15 I think
There's a picture of what it looks like HERE   s:wink: :wink: s:wink:
nitro
i use a g clamp.  s:wink: :wink: s:wink:
Quote from: "nitro"i use a g clamp.  s:wink: :wink: s:wink:
  s:shock: :shock: s:shock:
and how prescisely did you wind it in with a g-clamp  s:roll: :roll: s:roll:
on most cars the piston will push back without too much of a problem. The G clamp will work as will a screwdriver between the brake pad and disk. By all means spend 15 quid but I doubt that you'll find mr T's technicians using a special tool.
And after you have knackered the threads in the caliper by using a G clamp £15 will seem very cheap indeed   s:wink: :wink: s:wink:
I'm quite prepared to learn here.
So does Toyota use different calipers to most other manufacturers?
SteveJ
Fronts just push in (using a G-clamp). I know - I spent this morning changing my front pads and disks (less then 1mm of pad left on them   s:oops: :oops: s:oops:  )
Rears need the wind back tool due to the auto-adjuster for the handbrake.
HTH
Quote from: "sandstrain"I'm quite prepared to learn here.
No, because Vauxhall and many others are the same.
The rear calipers (only, not front) screw back in - inside the caliper they are threaded, and it's this thread which is the self adjuster for the handbrake.
You can't just push them straight back in - if you can, it's broken.
[edit] Which Steve already said  s;) ;) s;)
Here's a question that needs to be thought about, if the caliper is threaded why does the wind-back tool need to be locked on the opposite side of the caliper and have a threaded stem to push the piston back - are the threads on the wind-back tool the same as the inside the caliper  s:?: :?: s:?:
I did use the tool to rotate the piston to line up with the peg on the pads, in fact I rotated through 360 deg and it did not appear to go inwards, indicating that the piston was either not threaded or the thread was very fine - which would be in conflict with the wind-back thread which is course.   s:? :? s:?
Any way I did use the tool for both rear calipers - it worked but not exactly as I thought it would  s:? :? s:?
Rob.
Oh yes I forgot, if the piston is locked against the pad (peg on the pad) when you apply the brakes it will not rotate - so the piston is pushed out and does not rotate - so what's going on here then, is the rotating when you replace the pads something to do with the seals as you push back??????? It's like a chicken and egg question this one  s:oops: :oops: s:oops:
Innocent
Replaced the pads yesterday and yes, as already mentioned, the windback tool is 100% necessary. As aaron said, you could possibly get the piston back in with a g-clamp if you're feeling strong but the high risk of screwing up the thread on the handbrake ratchet isn't worth the £20 for the tool! Was hard enough work to wind the piston back in with the tool with one hand holding up the caliper.
