which sensor
Started by Anonymous, February 29, 2008, 15:02
hi guys
could someone please tell me which o2 sensor i should be ordering frrom the list below to replace the one with fault code p0141 , i can't seem to find the beck/arnley  one that was recommended
thanks for all you help
 w www.rockauto.com w
 2000 TOYOTA MR2 SPYDER 1.8L 1794cc L4 FI (R) [1ZZFE] : Emission : Oxygen Sensor    Related Parts
Item Price Core Total
DENSO Part # 2344607
Rear
BOSCH Part # 15733  {Oxygen Sensor}
4 Wire; Heated; Check / Replace Interval: 100,000 Miles; Universal Type - Downstream
Two required; 4 Wire; Heated; Check / Replace Interval: 100,000 Miles; Universal Type - Upstream
BOSCH Part # 13354  {Oxygen Sensor}
Two required; 4 Wire; Heated; Check / Replace Interval: 100,000 Miles; OE Type - Upstream
DENSO Part # 2344624
Front
STANDARD MOTOR PRODUCTS Part # SG802  {UPSTREAM SENSOR}
Two required.; Upstream Sensor
ACDELCO Part # 2131483 {#88929910}
SENSOR,HTD OXY(POSN 1) IN EXH MANIFOLD/CROSSOVER-4 WIRE
 sTANDARD MOTOR PRODUCTS Part # SG829  {DOWNSTREAM SENSOR}
DOWNSTREAM SENSOR
BOSCH Part # 13900  {Oxygen Sensor}
4 Wire; Heated; Check / Replace Interval: 100,000 Miles; OE Type - Downstream
ACDELCO Part # 2133021  {#19107365}
SENSOR,HTD OXY(POSN 3) POST CONVERTER-4 WIRE
* Non-stock item--shipping delayed up to 12 business days
AIRTEX Part # 5S4116
(In Manifold)
* Non-stock item--shipping delayed up to 2 business days
enid_b
i think its this one
please wait for confirmation from others first.
it is the 3rd sensor you need, with the long(er) wire, but essential point is that it is definately the 4 wire you need.
E
thankyou enib b
could someone please confirm that thats the one i need
Yes indeed it is the third O2 sensor (after the catalyst).
A search would have revealed that nugget of information   s:wink: :wink: s:wink:
It has the longer lead so you're looking at "downstream" replacements.
