Windscreen wiper
Started by gun41, March 31, 2008, 12:58
gun41
Hi
i need a new wiper for my 2
MrT quoted £23.28 seems expensive to me
Is a generic just as good?
what price?
2005 55 Plate, Silver, Red Leather Seats, TTE Style Bar, TTE Rear Sports spoiler, Chrome Fuel Surround
DannyN
Mr T can just replace the blades think it cost about 7 quid and they will do it for you while you sit in the showroom
[/size]
SteveJ
Or order a pair of Aero-VU wipers from eBay (loads of different suppliers) - much better than the OEM ones and only about £24 for the pair.
I've had MrT replace my rubbers dead cheap and there's nothing wrong with them. Can't see the point in spending anymore on blingy stuff.
Quote from: "Wabbitkilla"I've had MrT replace my rubbers
Now THAT is what I call a personal service level Nick!
Steven Velocity
Yeah, £23 has got to be for the whole wiper blade. As long as you don't have an aftermarket wiper blade (the part that the rubber wiper insert goes into), and you're not missing either of those 2 pesky little metal bars that hold the rubber in place Toyota should put a wiper rubber in for you for less than 5 quid.
DRUM & BASS IS THE ANSWER, wobble wobble...HARD TECHNO ALL NIGHT LONG! BLOWN 2ZZ (R.I.P.) (FI project]/PFC/J&S Interceptor/complete custom 2.5" exhaust/6pd w/LSD/8lb aluminum Fidanza flywheel/ACT eXtreme clutch/TRD quickshifter/Speedsource brass shift cable bushings/BC Racing RAM coilovers/Woods slotted rotors/Hawk Pads/Saner 25.4mm front sway bar/Corky\'s BP/Kirks mounts/custom roll cage/JDM hardtop/Dev\'s KHCs/clear corner markers/150lbs added lightness/Toyo R888 for now BWAHAHAHA!!!
Liz
 s:roll: :roll: s:roll:  @ Russ!
I bought new ones from Mr T the other day - £10.55 for the both of them and that was with the blades and everything - he took my chassis number in order to get the parts cheaper for me  s:? :? s:?  , I was well chuffed!  s:D :D s:D
On the subject of wipers and stuff has anyone done the single wiper conversion that is available???
gun41
thanks for all your posts
just rang Mr T in Wigan - they will replace the wiper blade rubber for £6 + vat
Southport Mr T seem to be trying to rip me off
Quote from: "gun41"Southport Mr T seem to be trying to rip me off
Noooooooo!
Would they ever?   s:lol: :lol: s:lol:
Sometimes makes me think we should be able to report garages for shoddy behaviour!
red_leicester
£1.25 in Wilkinsons.    s8) 8) s8)
[size=84]Jez[/size]
[size=75]2001 Red MR2[/size]
normanh
mmm a pair of Bosch with deflectors for less than a tenner the pair at my local motor factors, dont think you can do much better than Bosch.
normanh
Jaik
Quote from: "normanh"mmm a pair of Bosch with deflectors for less than a tenner the pair at my local motor factors, dont think you can do much better than Bosch.
normanh
Best wipers I've ever had were PIAA ones; basically as good as Bosch with Rain-X  s:) :) s:)
ChrisGB
Another vote for Bosch ones here. I use them on everything, wipe better than almost anything else (never tried PIAA) and last well too.
Chris
i've got to say i think the Bosch ones are crap, always had issues with them, Mr.T's ones are far better
Has anybody tried the "new" flat blades?
Like Jaik said, I use Rain-X, probably why I'm still on my original blades.   s:wink: :wink: s:wink:
wbarrwebster
Bought the flatter, non spring Wiper blades for both the "2" and my youngest's Fiesta from EBay about 3 months ago.........work ok so far!
To repeat an earlier question, has anyone fitted the single large wiper?
Cheers,
B
W. B. Webster
Here's a link to the units made by Storm
 m http://www.autotintdesign.com/singlewipers.html m
Demon Tweeks also sell the same thing - I've never seen one fitted.
Rob
Jaik
What's the point of the single wiper conversion? Just to "look like a racing car"? Not having a go if that's why people want to do it, just curious if there's any benefit.
Ilogik
would something like this work ok?
 m http://cgi.ebay.co.uk/RETROFIT-FLAT-Wip ... 286.c0.m14 m
 m http://cgi.ebay.co.uk/Toyata-MR2-MK3-20 ... 5394wt_941 m
or does someone have a link to a pair.
Ex: TRD stage 1 TTE Turbo
Ilogik
Ended up popping up to local motor factors picked one up a set of bosch supers for £8 for pair, seem to work ok.
ChrisGB
One thing that always bugged me about the MR2 is the way the aerodynamics throw a lot of trails of screen wash up the middle of the screen. The water seems to cling to the frame of the wiper and stream its way up the screen after washing. I thought I would try some Trico flat blade replacements out and so far I would say they do a better job than the Mr T ones I had on before. Much less water streaming up the middle of the screen and a good wipe generally.
I also got a set for the Mini and on there, they are maybe not as good as the OEM items.
Chris
Ilogik
the thing i hate is if your driving with the window open and use the window wipers youg et a car full of water.   s:cry: :cry: s:cry:
