1ZZ..
Started by Anonymous, April 26, 2008, 21:39
Hi folks, just a quickie - what is the full engine designation for the standard MR2?  I've tried researching it, and I come up with :
1ZZ-FED
is that the same as a 1ZZ-FE ?
P.S. this is for an oil filter; there's 3 types for different engines.
theres only one type of filter, small screw thread type, all 1ZZ's use the same. If you want a recomended one then call amber performance and ask them for a K&N gold filter p/n HP1003
I was actually thinking (of the slow move over to TRD territory) to start with the TRD Oil Filter?
Good or bad?
K&N is better
Better? Well, this is worth looking at   s:shock: :shock: s:shock:
On a similar note, OpieOil's latest offer (for those who subscribed) on Purolator Filters - are they any good for air filters or are there better brands out there (which don't enhance performance to the extent of the APEXi)?
Another thought also - will fitting this non-standard filter void my dealership warranty?
northernalex
Quote from: "GroundZero"Another thought also - will fitting this non-standard filter void my dealership warranty?
It shouldn't. At the durham toyota they told me that you could fit non-standard parts, and although they didnt cause other parts to fail then your warrenty would be ok.
by the way, I have an opie puroillater oil filter and it seems ok.
Best,
Alex
evileye_xc said:
Liz
I have an opie puro watsitsface on my TTET and it has been fine so far!
