Misfire - Engine Light on
Started by dlivingstone_19, May 5, 2008, 11:46
Innocent
#50
Sounds like a logical way of working it out, but i've not got much mechanical knowledge so cant really advise! Would be really interested to know the outcome of this though to see if this is a decent way of working out if there are problems with injectors.
#51
Swap the injectors around and see if the problem follows the injector (bad injector) or the wiring - it's an easy job when you get down to it.
If it's the injector then you could try getting it professionally cleaned, but if it's simply not firing then it could be the coil - in which case it's either get it remanufactured (hard to find in this country, it seems) or replace it.
If you replace it, best to get the remaining three flow tested at the same time, if not replaced, to ensure they are all flowing the same amount of fuel.
dlivingstone_19
#52
How comes once I left the car for a couple of days and then started driving again it felt completley fine?
Could an injector have a Intermittent fault?
Are they any other signs for an injector at fault?
How easy is it to remove an injector, whats the process?
Sorry about all the questions.
** Racing in the Caterham Academy for 2013 Thanks to Pistonheads, Autosport and Caterham **
Toyota MRS Spec:
Trd front splitter, Trd Side skirts, Trd Rear Spoiler, New style Rear Lights, 17inch Dezent Motion Black Alloys, Cobra Quad Exit Exhaust System, Markiii Inlet Pipe & Sony Cd Player
dlivingstone_19
#53
Any advice please?
Toyota MRS Spec:
Sorry my friend - please read this to end   m http://www.mr2roc.org/phpBB2/viewtopic. ... ht=misfire m
Looks exactly the same to me:wink:  You just need a Ste to sort it out  s:D :D s:D
dlivingstone_19
#55
It does sound the same as what I'm experiencing. How much do injectors sell for roughly?
Toyota MRS Spec:
Quote from: "dlivingstone_19"It does sound the same as what I'm experiencing. How much do injectors sell for roughly?
I'm not sure, but I'm sure there are some floating around within the club - put a wanted request in the for sale section.
Rob
#57
I have some injectors, although I'm currently down to three after the fix on Pam's car that Rob mentions and I'd like to get that back to a complement of four if I can...
However, I'm sure someone on here will be breaking a set. If you are, and you're reading this, perhaps you'd consider selling one to Livi and one to me (via Pam)?
Rob's diagnosis on Pam's car was spot on and simply done with a plug-out sniff test across the chambers to confirm no fuel getting through to cylinder 3.
Not being able to read any JSpec codes is no big deal because if you threw any CELs an injector problem would manifest as an ignition code in any case!
If you need further confirmation, do the sniff test.
Aside: I stumbled across a very good way of checking coil packs/plugs this week: piece of pipe held firm on the top of the coilpack and up to your ear - you can hear them tick/tick/ticking with very little disturbance from other noises.  s8) 8) s8)
*edit - can't remember where you live, but you're welcome to head this way if you need some help. I think I may have some new spare injector o-rings kicking about too (if i can find them  s:oops: :oops: s:oops:  )
dlivingstone_19
#58
I live in Tunbridge wells in Kent so bit too far from you. Cheers for offer though.
How do you remove injectors? Any pics?
Toyota MRS Spec:
#59
Something somewhere on spyderchat I think  s:?: :?: s:?:
Its more fiddly than difficult....
Disconnect battery and put all cigarettes out.
Vent pressure from fuel tank
Unclip injector connections and harness ties to give a bit of room
Remove two bolts holding the rail
Ease the rail up, getting newspaper underneath the 'jectors as they come out
*injectors have a rubber seat at the base....if this doesn't lift off with the injector make sure that it hasn't come adrift from the cylinder head (small mirror handy for this)*
More newspaper to catch fuel as you pull the offending injector out (its a firm interference fit - needs a good wiggle)
Replace with new injector and preferably new top O-ring
bolt everything down and check that injectors rotate slightly with equal resistance across all four.
Reconnect etc.... fire up and check for leaks
dlivingstone_19
#60
I think this might be a job too far for me. I have replaced plugs and coil packs but this looks too complex for me to do.
Any preference on where to take car to get work done?
Toyota MRS Spec:
Pam - MR2 Only
#61
Like Ste said if anyone is selling single injectors I would like to buy one to replace his   s:lol: :lol: s:lol:  its the least I can you for this fine man
Pam
 w www.mr2only.com w
www.mr2only.com - The ONLY dedicated magazine for the MR2 enthusiast worldwide
dlivingstone_19
#62
My car is going to looked at by a Toyota Japanese Import Specialist tomorrow. Sure he will tell me whats wrong.
Fingers crossed
Toyota MRS Spec:
dlivingstone_19
#63
Just had garage on the phone saying its an injector at fault .... what I thought. They are going to call me back with a price?
How much should I expect for an injector plus fitting?
Toyota MRS Spec:
 s:D :D s:D    s:wink: :wink: s:wink:
dlivingstone_19
#65
Injector is going to take 2 days to come in   s:( :( s:(  As there a Specialist and not a main dealer don't have part instock. Pain in the A**.
Toyota MRS Spec:
