225's on standard 16's - Will they fit?
Started by Anonymous, May 8, 2008, 11:37
I've done a quick search but couldn't find a topic that covered my question.
Will 225/45/16 fit on the standard back 16's on my 2004 roadster?
It currently has nearly bald 215's on there but I want to go wider   s:twisted: :twisted: s:twisted:
Did you look here ? Click   s:wink: :wink: s:wink:
225x40x16 is what you are looking for.
Toyo T1R is the tyre you want.
ChrisGB
Quote from: "jeb"I've done a quick search but couldn't find a topic that covered my question.
They will fit on the 16" rims. How much wider is open to debate as the wider you go, the more you pull in the sidewalls on the relatively narrow rim. I run 225/45 R16 (Hankook RS-2) with no problems. I did get a very slight loss of acceleration due to the 3% taller gearing (the tyres are slightly bigger rolling radius than 215/45s).
225/40 may be better in this respect, but you may be right at the bottom end , or below recommended rim size for some types of tyre. Hankook, for example specify a 7.5" rim minimum for a 225/40 tyre.
Chris
I'm runnit 225x40x16 Toyot T1Rs on the rear - no problems!
ChrisGB
Quote from: "Wabbitkilla"I'm runnit 225x40x16 Toyot T1Rs on the rear - no problems!
The Toyos soft sidewalls make them pretty tolerant of smaller rim sizes. IIRC Toyo reckon you can go to a 7" rim on that size, so it is probably the best size to run for T1R.
Chris
fstsven
They fit perfectly.
I run 225/45/16 Toyo T1-R's, no probs.
My 205/50/15 on the fronts is pushing it though   s:wink: :wink: s:wink:
2004 fire red TOYOTA MR
K&N air filter
BLUEFLAME single exhaust
3.ORACING breastplate
25 kgs extra lightness
they will fit....but it will have that rounded donut look because the tyre width is much wider than the 7inch rim. I just had Falken FK452s 225/45R16 fitted yesterday.
Although, a half to one inch wider rim would no doubt add some weight despite looking a little nicer.  s:wink: :wink: s:wink:
