Which oil filter wrench?
Started by Leeber, May 8, 2008, 11:53
Leeber
Hi folks,
I'm just about to do a 5k oil & filter change on my '2, I was just wondering if anyone had an opinion as to which tool is easiest to use for removal of the old filter? There's a screwfix not 100 yards from where I live so unless anyone's got any horror stories with regards to their offerings, I was planning to make that my first port of call. Specifically, I was looking at these two products:
Pliers
Wrench
Anyone got any experiences with either of these?
TIA, Lee
SimonC_Here
Am I allowed to say I used my fingers!   s:oops: :oops: s:oops:
It's not exactly hard to get to.
Oh and some filters have standard hex bolts on the end of them.
Simon
Difficult to get access and leverage with pliers because of the inset location of the filter. Wrench is better for our car.
Better still is what I've just ordered (previously I've been succesfully using a tried and tested method of jubilee clip and mallet!). I tried SteveV's out when he was over here and its a treat on the '2 .... a mod of the three-leg wrench - with two spring-loaded jaws.
Ordered from US. Steve was planning a GB on these but I've heard nothing from him.
Leeber
Simon - Of course you are, I never thought of trying that  s:oops: :oops: s:oops:  . My current filter's just a stock one (car's still under warranty) so I don't think it's got a bolt on it.
Ste, where did you order that from (got a link)?
Cheers for the replies.
Quote from: "Leeber"I was just wondering if anyone had an opinion as to which tool is easiest to use for removal of the old filter?
The OEM Toyota SST, which was less than 10e?  s8) 8) s8)
Looks like this:
What Tem said - that's a good deal.
The universal is Clicky. UK shipping is $15.
Leeber
That was a lot easier than I thought it would be - brilliant!
Thanks again guys.
your second link Lee don;t work I have one and they don;t go small enough for teh roadsters filter
your first option as said willstruggle to fit
I'd go with Tem or Stes options
or cheat like me and only use K&N Gold filters which have a welded on nut  :-) :-) :-)
Leeber
Quote from: "Tem"The OEM Toyota SST, which was less than 10e?
Just rang my local Mr T, the Crawley branch refused point blank to supply it, Horsham wanted £30+vat   s:shock: :shock: s:shock:  .
Perhaps I'll try and source one from the continent.
as opposed to the incontinent?  s:wink: :wink: s:wink:
email Chris Billimore at cheaptoyotaparts ( e mailto:Chris@cheaptoyotaparts.co.uk">Chris@cheaptoyotaparts.co.uk e ). He's a very helpful guy. I believe he sources from (usually) Belgium to bring us Euro deals.
If the part is available to him, he can give you a price direct to the door.
Whack a screwdriver through the middle of the filter and turn it out that way. Proper men only need apply, as you will get covered in oil.  s8) 8) s8)
Quote from: "Ekona"Proper men only need apply, as you will get covered in oil.  s8) 8) s8)
I seem to remember having to take a certain members off in exactly that way recently.. and yes, got covered in oil (but when don't I?)  s;) ;) s;)
Generally if I've put it on, then I can get it off again with my hands (hard, but possible)
That's how mine came off when we did the turbo install. Talk about getting chucked in at the deep end!  s:lol: :lol: s:lol:
Oh my, that sucks.  s:shock: :shock: s:shock:
I just took the part number from BGB and my dealer had no issues selling me one.  s8) 8) s8)
Quote from: "Ekona"Whack a screwdriver through the middle of the filter and turn it out that way. Proper men only need apply, as you will get covered in oil.  s8) 8) s8)
  s:lol: :lol: s:lol:    s:lol: :lol: s:lol:    s:lol: :lol: s:lol:   Thats what I love about modern technology! Some things don't change. What was it?  If your only tool is a hammer, then every problem starts to look like a nail! I've actually used an old belt as a sort of strap wrench on many occasions.
It's kinda hard to tighten the new filter as instructed with a screwdriver though.  s:lol: :lol: s:lol:
YMMV and all that stuff, but the SST really made my oil changes a lot easier. I can do it on a level ground now. Just reach for the filter from the side of the car, in front of the rear wheel and it opens easily. Just need a low enough container, which fits under the oil pan and holds enough oil.
I do have a garage where I could lift the car, but I don't bother with that anymore.  s8) 8) s8)
Here in the states we have a special tool called the "5 finger on the hand tool."  In other words it should be only hand tightened.
Quote from: "kaustein@hotmail.com"Here in the states we have a special tool called the "5 finger on the hand tool."  In other words it should be only hand tightened.
your right though, you dont need tooling to tighten it, it should be fitted as tight as you can by hand and nothing more.
Steven Velocity
Quote from: "spit"Difficult to get access and leverage with pliers because of the inset location of the filter. Wrench is better for our car.
Speaking of group buy,
 http://www.mr2roc.org/phpBB2/viewtopic.php?t=21184&highlight=
My completely biased opinion says that this is the oil filter wrench you need!
DRUM & BASS IS THE ANSWER, wobble wobble...HARD TECHNO ALL NIGHT LONG! BLOWN 2ZZ (R.I.P.) (FI project]/PFC/J&S Interceptor/complete custom 2.5" exhaust/6pd w/LSD/8lb aluminum Fidanza flywheel/ACT eXtreme clutch/TRD quickshifter/Speedsource brass shift cable bushings/BC Racing RAM coilovers/Woods slotted rotors/Hawk Pads/Saner 25.4mm front sway bar/Corky\'s BP/Kirks mounts/custom roll cage/JDM hardtop/Dev\'s KHCs/clear corner markers/150lbs added lightness/Toyo R888 for now BWAHAHAHA!!!
