10w-40 oil ok?
Started by Ilogik, July 15, 2008, 13:03
Ilogik
Hi im new, just want to check this is the right oil? or if its ok, Had an MR2 turbo previously  and a mk2 n/a before that one so I love my MR cars. My other question when is the best time to check the oil on the car? I checked it today, one side of the dip stick showed half full where the other side showed full. The stick is tricking me lol.
Ex: TRD stage 1 TTE Turbo
I usually just start the engine up for a minute then turn it off, check the oil then and it should have warmed up slightly and give you quite a clear reading.
I think 10w/40 oil is OK but I think it's recommended to use 5w/40 with the car. I've got 0w/40 Mobil1 in mine at the mo and I'm checking it tonight to see how it's going.
kentsmudger
Quote from: "onion86"I usually just start the engine up for a minute then turn it off, check the oil then and it should have warmed up slightly and give you quite a clear reading.
Surely some of the oil is now slowly trickling back down to the sump and not being measured?
