Precat inspection
Started by ad_car_08, August 2, 2008, 15:13
ad_car_08
Hi,
I'm off to look at an MR2 mk3 for sale, shortly.
I'm aware I need to check the precats, but do I need to check under both oxygen sensors for precat deterioation??
[/size]
You will only be able to check the tops, the two o2 sensors in the top of the manifold through the holes in the heatshield. It is only a guide as you are only seeing one end of each precat. You will need an o2 socket to remove the o2 sensors, 22mm rings a bell iirc.
